The SOHC/4 World Tour is in under way.
The rope trick works by feeding the rope into the cylinder through the spark plug hole. It fills up the combustion chamber and prevents the valve from falling in. You can also do the same with an air compressor and an adapter from a compression tester that threads into the spark plug hole. The compressed air keeps the valves tight in their seats.
By rope trick I thought he meant just a mystical way of doing it.
Quote from: MCRider on October 01, 2010, 07:02:03 AMBy rope trick I thought he meant just a mystical way of doing it. That's how David Copperfield would do it!A large silk sheet, a lovely assistant in a sequined bikini, and a length of rope.
