Author Topic: Can you fit seals onto stock CB400f exhaust valve guides?  (Read 1088 times)
Offline jessezm
  • '77 cb400f cafe build
  • Always wrenching...
« on: October 01, 2010, 01:44:59 PM »
Do you need to purchase aftermarket guides in order to get seals on the exhaust valve guides, or can you just get a set of Viton seals and install them on the stock guides?
I think I will be tearing back into my top end and I'd love to add seals to the exhaust guides if it's that simple.  I'd rather not take the whole head back to the machine shop to have new guides installed and all that goes with that...  If that's the case, I'll just live with a little smoke
Thanks!
Offline Bodi
Re: Can you fit seals onto stock CB400f exhaust valve guides?
« Reply #1 on: October 01, 2010, 03:05:49 PM »
The exhaust guide does not have the profile that retains the seal, so no.
Offline jessezm
« Reply #2 on: October 02, 2010, 05:50:59 AM »
Thanks, that's what I needed to know
Offline hoodellyhoo
  • CB350F
« Reply #3 on: October 02, 2010, 07:46:20 AM »
I just broke out my 350f parts book and it shows seals on the exhaust so maybe you could find a cheap 350f head to swap?
Offline malcolmgb
  • What am I not? an
  • The BEST 400 four by far
    • malcnet
« Reply #4 on: October 02, 2010, 10:39:08 AM »
Why would you want seals on an exhaust valve guide?
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
Offline jessezm
« Reply #5 on: October 02, 2010, 10:49:58 AM »
Well, peace of mind I guess.  It'd be easier to tell whether the rings had seated on my fresh top end if I could eliminate the possibility that the bit of smoke I get from time to time was coming from oil coming through the exhaust valves.
