Author Topic: 73 CB500f Tailight ?  (Read 431 times)
Offline dulcimerbob
« on: October 05, 2010, 07:15:27 PM »
Got my bike on the road today ;D One problem. When I turn on the switch the headlight comes on , the brake lights work but the tailight doesn't. If I turn the switch to the Park position the tailight comes on. Any ideas ?
Offline Lavis500
  • Why don't you go ask a
  • "Don't plan vast projects with half-vast ideas"
Re: 73 CB500f Tailight ?
« Reply #1 on: October 05, 2010, 07:27:05 PM »
Start with obvious stuff first.  You said it works in the park position, right?  Sounds like something has to be right. Run a multimeter across the different positions on your ignition switch to make sure everything is going right and you have connectivity in the right places.
If nothing you can get a wiring diagram and check all of the electrical connections going to and from the taillight, but I don't think that will matter as you said the light works under certain conditions.  If they are all connected, clean them all to ensure a good contact and reconnect.  If still nothing, place a multimeter across each individual wire to check for connectivity.
Let us know the results, and we'll take it from there.
OH, and BTW it's a CB500K2.  There is no "500F"  ;D
"Whatever it is, I swear I didn't do it!"
'73 CB500 - Sally
