Author Topic: Help with carb fuel lines  (Read 405 times)
JMichael
« on: October 06, 2010, 01:00:28 PM »
I have recently started to work on a 1974 cb350f. It would not start so I tore down the motor to the base case. It had bad compression and I thought it might be a blown head gasket, however upon further inspection the head gasket looked good. While I have everthing apart, I thought I would take a close look at the carbs. I found one nipple with a fuel line attached and two nipples above that with nothing attached. I'm not sure what they are, fuel line nipples or maybe vacumn nipples. I have a clymers shop manual, but I can not find any reference to these two nipples.
Mike
Re: Help with carb fuel lines
« Reply #1 on: October 06, 2010, 01:28:23 PM »
just vents.  tube them.  run them out near your airbox, and down between your lower case and rear tire.
JMichael
« Reply #2 on: October 06, 2010, 01:51:30 PM »
Thank you.
Mike
