Author Topic: Dyna coil installation HELP  (Read 975 times)
Offline ksmith0034
  • When I grow up I want to be a
    • Please subscribe to my motovlog
« on: October 06, 2010, 06:11:52 PM »
I got my Dyna care package from Z1 today, but I've run into a problem.  I can't find anywhere in the instructions which port on the coils are for which cylinder.  I know the cylinders are split 1 -4 and 2- 3 between the coils, but which plug wire goes where?
It took 10 years but she's finally done!
Stocker 2 Rocker CAFE conversion
My YouTube channel HERE:
https://www.youtube.com/MotoCafeRacer
Offline swellguy
  • An electric cattle prod is a
  • Divorce is so expensive because it's worth it.
    • http://ksphotos.com
Re: Dyna coil installation HELP
« Reply #1 on: October 06, 2010, 06:13:36 PM »
It doesn't matter.
This project started in confusion and will end in disarray.
http://forums.sohc4.net/index.php?topic=76471.msg852227#msg852227
Offline ksmith0034
« Reply #2 on: October 06, 2010, 06:14:49 PM »
That would explain why the instructions don't mention it I guess...
Thanks.
Offline wookie
  • I would get up if i knew i fell
« Reply #3 on: October 07, 2010, 06:27:52 AM »
same goes for the small wires.  the coils aren't polarity sensitive either.
Offline ksmith0034
« Reply #4 on: October 07, 2010, 07:04:16 AM »
Ya, the instructions said that the small wires don't matter - it just didn't state anything about the plug wires.  But I went ahead and cut my wires last night and got the coils set up.  Now I just need to install the Dyna S and see if she'll light the fire!
Offline Coyote13
« Reply #5 on: October 07, 2010, 08:04:20 AM »
I just did this same install... MAKE SURE none of your terminal wires are touching the frame when you install or they WILL ground out. Ask me how I know  ;D
'78 CB750K.  Throttle ripper.
'71 CB100.  Grocery getter.
'01 XL883.  Panty dropper. Gone but not forgotten.
Offline swellguy
« Reply #6 on: October 07, 2010, 10:26:54 AM »
I'll bite, how do you know?
Offline ksmith0034
« Reply #7 on: October 07, 2010, 01:19:07 PM »
Are you talking about the small wires?  It seems odd that they would ground through the sheath.  Did you have cracks or exposed connectors?
