Author Topic: FIRST WHEEL IS TRUED UP!!!  (Read 2471 times)
Offline johnsy
    • what I do!
« on: October 08, 2010, 09:18:16 AM »
This was my first wheel truing experience....im one of those people, if i can pay another human to do it i should be able to do it myself. so i gave it a shot and it wasnt as hard as i thought it would be. A little common sence, some time on your hands, alot of patience and im sure you can make it happen. Here is a breakdown.
I started here,
http://forums.sohc4.net/index.php?topic=19575.0
and took a few pointers from you tube
equipment wasnt as pricey as most think.
go to Harbour Freight:
TRUING STAND $59.00
http://www.harborfreight.com/catalogsearch/result?category=&q=wheel+truing+stand
MAGNETIC BASE $9.99
http://www.harborfreight.com/multipositional-magnetic-base-with-fine-adjustment-5645.html
DIAL INDICATOR $11.99
http://www.harborfreight.com/1-inch-travel-machinists-dial-indicator-623.html
alos you can find coupons for this place in the back of most powersports magazines...mine was %20 off instore purchase.
« Last Edit: October 08, 2010, 09:23:50 AM by johnsy »
current project, cb550 four
75 360T
Offline MaaseyRacer
    • Fuelist
Re: FIRST WHEEL IS TRUED UP!!!
« Reply #1 on: October 08, 2010, 01:47:44 PM »
I just used a vice, and a piece of wire attached to a solid block. It does not take much to get a wheel round and true. I dished the front wheel in the fork, and the rear wheel trued up dished.
Your wheel looks good though.
1961 CB72
1961 CB77
1962 CB77
1962 CB77
1965 CB160
1970 Triumph Bonneville
1972 Honda CB450
1975 Norton Commando
Offline rachet
  • '77 CB750 F2
« Reply #2 on: October 08, 2010, 02:16:19 PM »
I love the look of the white rim.   Are you going to post pictures when they are mounted?
Good job on the hard work.
But I need Tacos!  I need them or I will explode!
Offline johnsy
    • what I do!
« Reply #3 on: October 08, 2010, 02:48:03 PM »
that is a good way... i have seen variations of that. I plan on doing alot more of these so i figure make the investment now and I hope to put some people at ease that its not a crazy expensive investment.
75 360T
Offline johnsy
    • what I do!
« Reply #4 on: October 08, 2010, 02:49:27 PM »
Thanks sir,
yeah ive got a couple of build threads going now and im posting as i go.
75 360T
