Author Topic: Front brake squeeze or no squeeze  (Read 1145 times)
howardstapley
« on: March 09, 2006, 05:14:03 PM »
OK and here’s the next question. The front brake on the cb350F does work if I just slowly squeeze it, only if I grab it hard (sounds like a girl I once knew) plus there is a light dab of brake fluid on the master cylinder, time for a master cylinder rebuild or replacement?
Offline Bob Wessner
  • "Carbs Suck!"
Re: Front brake squeeze or no squeeze
« Reply #1 on: March 09, 2006, 05:27:29 PM »
Sounds like a rebuild might be in order. If it's leaking fluid out, could be leaking air in.. not good. I would consider disassembling and inspecting the entire brake system from the M/C on down to the caliper if its history is unknown to you.
Offline KB02
« Reply #2 on: March 10, 2006, 05:47:50 AM »
I agree; sound like time for a rebuild. And replace the hoses while you're there. Braided Stainless is best, but new from Honda (rubber) works, too.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
