Author Topic: Preferred Gasoline  (Read 14614 times)
Offline Lavis500
  • Why don't you go ask a
  • "Don't plan vast projects with half-vast ideas"
Preferred Gasoline
« on: October 11, 2010, 02:18:22 PM »
So I was reading through the CB500's owner's manual when I ran across something I hadn't seen or expected:  "It is recommended that 90 or higher octane number gasoline containing a small percentage of lead."
I don't mean to sound so young, but are our bikes meant to run on leaded gasoline?  I thought gas was either leaded or unleaded.
Also, on a second note, has anybody ever used the "park" function of the ignition switch?  How long can you leave it like that before you begin to see your battery suffering?
"Whatever it is, I swear I didn't do it!"
'73 CB500 - Sally
Offline weekend_junkie
  • I bet you think I'm some
  • Member # 15859
Re: Preferred Gasoline
« Reply #1 on: October 11, 2010, 02:35:26 PM »
Park is a handy thing if you are stopped on the side of a highway at night for an emergency and do not want to kill your battery by having the headlight on.
You got me on the lead part.  Can't be as bad as ethanol.
Dan
Offline cookindaddy
  • I sure love this bike!
« Reply #2 on: October 11, 2010, 02:42:27 PM »
Good question about gasoline.
When I got my new (old) bike two years ago, an old timer suggested that I only wanted to use high octane gas. Leaded gas is long gone around here.
After I got all the other problems fixed with my bike (750 K8) and got it properly tuned, it seems to be very happy running standard octane gas (the regular stuff at the pump). I have tons of power with flawless performance and I am getting 54 mpg (mostly highway driving).
We have about 10% ethanol at the pumps here in Ontario Canada. Ethanol has less energy than gasoline but at that ratio it is not noticeable.
Lead of course is a very lethal material.
« Last Edit: October 11, 2010, 02:48:10 PM by cookindaddy »
George with a black 78 CB750K (in Lion's Head, Ontario, Canada)
« Reply #3 on: October 11, 2010, 03:09:22 PM »
In the early 70's, the gas rating method in the US was standardized using the RON method and it all had lead added to it as a cheap way to prevent engine knock/ping.
Research Octane Number = RON
There are other methods of rating gasoline.   One of them is MON.
Motor Octane Number = MON
When unleaded gas became available, and to add confusion for consumers, the rating method was changed to the
(MON + RON)/2.  This became the "pump octane number" that they labeled the pumps with.  This is 4 or 5 numbers lower than a true RON rating.
http://en.wikipedia.org/wiki/Octane_rating
The lead in the gas also lubricate cast iron valve seats commonly used in engines of the era.  Without lead and under engine high loads the cast iron seat wore rapidly.  Newer engines for unleaded fuel have steel valve seats in the head.
The aluminum head on the SOHC4 already has steel seats for the valves.  So, it does not really need leaded fuel for either lubrication or an octane boost.
Offline Lavis500
« Reply #4 on: October 11, 2010, 03:21:31 PM »
Thanks for the info, TT!  I'm glad I could get an expert to chime in on it.  I didn't think it'd be an issue running today's unleaded gas in it as I'd seen others doing this, but I really appreciate the explanation behind my findings.
'73 CB500 - Sally
Offline 333
  • Time for change
« Reply #5 on: October 11, 2010, 04:34:51 PM »
So true.  It was like Honda had a crystal ball.  They knew lead was going away and made their engines accordingly.
Ethanol is another story.  In the burning process, ethanol creates carbon, much more than gas without ethanol.  And carbon is harder than steel.  Not so much of a problem with cars, because higher heat is needed, as in the difference between water cooled and air cooled engines.  And the heat is even higher in 2 stroke engines.  I know of 2 products to help.  BG 44K (expensive) and Seafoam.  Use one of these in anything air cooled that you own.  The 44K might be good as a start, to clean out built up carbon.  Then Seafoam as a regular additive to keep it clean.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline 1974CB750rider
  • 1974 CB750K4 46000 miles
« Reply #6 on: October 11, 2010, 06:06:24 PM »
I still find my bike seems to get better mileage when I use 93 instead of 87. It doesn't cost much to fill these bikes up anyway so I always run the good stuff in mine.
People with closed minds cannot learn new things.
« Reply #7 on: October 11, 2010, 07:01:26 PM »
Ethanol is crap and absorbs moisture, no wonder our American members have so much trouble with carbs and rusted fuel tanks. I refuse to use ethanol in anything, it is corrosive crap and does nothing to make the fuel any safer.....once again we have been fed mis truths and swallowed it hook line and sinker. Unleaded fuels are now much more poisonous than the leaded fuels they replaced.
Online Don R
« Reply #8 on: October 11, 2010, 07:10:29 PM »
I regularly buy race gas at the drag strip and if it was permissible to add a drip of two to my bikes gas tank for a little valve lube I would once in a while. But I don't- unless I'm going off road, yeah that's it, off road, only, thats when I do it. yeah. like if I was off road in the desert, you know, right?
Offline Johnie
« Reply #9 on: October 11, 2010, 07:16:10 PM »
I only use non-ethanol in my 750's now. I just had a bad feeling every time I filled with ethanol. So I first tried it out for a while on the daily rider K4 and all ran very well. I then did the K1 and then KO. I did not notice any problems with the higher octane, but now have piece of mind with the non-ethanol.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline bird
« Reply #10 on: October 11, 2010, 07:34:59 PM »
Australia killed off lead petrol, and my CB750 hasn't been happy since. Do any of our American and International cousins use products like Valvemaster additive to compensate for the lack of leads benefits? It's recommended here for old cars and bikes.
http://www.valvemaster.com.au/Win_ie/going.html
Offline Lavis500
« Reply #11 on: October 11, 2010, 08:31:39 PM »
I wish I could escape ethanol, but in TX it seems kinda hard.  I was living it up on my summer road trip when I was going through Iowa, Indiana, Nebraska, etc.  My truck (07 chevy silverado 5.3 V8) saw an increase of 3-5 mpg. I know that doesnt sound like much, but going from 14 to 17  city and 18 to 21 highway is a drastic change!
It certainly does sound like Honda was thinking ahead of the curve.  All hail the Honda Gods.   ;D
'73 CB500 - Sally
Offline Brown Bomber
« Reply #12 on: October 11, 2010, 08:53:10 PM »
     I've been hearing lately of people getting stale 92/93 octane, because with this poor economy people are buying the lower octane to save money, and the premium sits in the tanks too long.
     I'll be switching to 89 octane, and adding some sort of octane boost, as soon as I figure out which octane booster to try. So far all the products I've seen claim to do miracles, but don't tell you what's in them. Is that a real poncho, or is that a Sears poncho?
     Any suggestions?
Keep the Shiny side up!
1987 ZG1000 "King Crimson"
1972 CB750K2 "Stout"
1976 CB500T "Witch's Promise"
1973 CL450K5 Cafe Project
        Vito Corleone
Offline ferroussphinx
  • hello and help me please lol
  • 1974 honda cb 750
« Reply #13 on: October 12, 2010, 12:29:14 AM »
hello brown bomber
check out myth busters   they did a test on all the major brand octane boosters and found that they did not help at all  in fact they reduced mileage and power in all live tests
honda cb750 1974
« Reply #14 on: October 12, 2010, 12:56:49 AM »
i use 98 in everything bird,i only used an additive once ,at half the dose and got red/orange deposits on my pistons and plugs,i threw the rest out.
« Last Edit: October 12, 2010, 01:00:45 AM by dave500 »
Offline Gordon
  • 750K1, 550K2
« Reply #15 on: October 12, 2010, 05:53:36 AM »
     Any suggestions?
Why do you need the higher octane rating?  Is your engine modified for higher compression?
« Reply #16 on: October 12, 2010, 07:21:14 AM »
87, and a splash of seafoam.
 8)
« Reply #17 on: October 12, 2010, 07:25:13 AM »
     Any suggestions?
Just trying to go by the book;
        Vito Corleone
« Reply #18 on: October 12, 2010, 07:30:48 AM »
Carbon can do that. In the Netherlands back then it was advised to tank leaded fuel every fourth time (for lubing effect).
« Reply #19 on: October 12, 2010, 07:44:39 AM »
Nonsense, it's not as you put it. Do some study. You can start with a search in Wikipedia.
« Reply #20 on: October 12, 2010, 08:11:50 AM »
     Any suggestions?
Which book is that?
AFAIK the 77-78 CB750F had the highest Comp. ratio of all the Cb750s.  See Below
Offline cobra2411
« Reply #21 on: October 12, 2010, 09:26:26 AM »
Yeah but if we didn't use Ethanol our corn farmers would starve, the planet would reach 1 billion degrees - killing all the polar bears and the terrorists would win...  ::)
I run 93 Sunoco because my Mustang GT likes it so much and it's not that much more expensive... Overkill maybe but that's my middle name.
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #22 on: October 12, 2010, 09:34:00 AM »
Higher octane will burn slower so you would have to retard your advance to get the maximum efficiency out of a higher grade octane.
Unless you have problems with pinging or knocking you are literally pissing your money away and getting no benefits out of it whatsoever unless the higher grades don't contain ethanol. I don't care to monkey around with my ignition timing any more than I have to because the regular 87 works fine.
If ethanol becomes a problem with my bike and they definitely do not mix ethanol in the higher grade I might consider it down the line.
« Reply #23 on: October 12, 2010, 10:10:09 AM »
I think you'll find this is exactly backwards.  With a slower igniting fuel you can ADVANCE the timing.
Pinging engines can sometimes be fixed by ignition retard.  But, you often lose some power band doing this.  It is an RPM related trade off.
« Reply #24 on: October 12, 2010, 10:18:00 AM »
Another discussion turning academic, I'm afraid, but I'll be a sport...
Can you tell us HOW MUCH slower?
