Author Topic: Yep...new guy, 'nother brake question  (Read 1191 times)
Offline Nortstudio
  • Not nearly an
  • Just getting started...
    • MotoPreserve
« on: October 17, 2010, 07:22:10 PM »
So after getting my new bike today, looking her over better than I had been able to at the sellers house, there are a few things need addressing sooner than later.
Top priority: Front Brake.  This is the first 2-wheeled anything that I have owned with disk brakes, so I am beyond new here.  The Front Brake lever barely pulls, it's very, very tight.  When I tested the bike, it worked OK, but not what I was expecting.  It comes nowhere near back to the bar - and although I know that it should not come back SO easy, it really doesn't want to come back at all.  I figured time for bleeding and new oil.  Then I noticed that the bleeder is really rusted, and doesn't look like it will come loose without snapping it like a twig (looks like someone may have tried).  So before I move on, I'd love to try bleeding the brakes first, but need to see if possible without the bleeder?
I found an old post that mentioned bleeding without using the caliper bleeder, but the link it pointed to wants to open a text file that is gibberish.
Does anyone know the link to such a procedure???
I'm in the process of reading the FAQ about the overhaul to the whole front brake too, so i will be moving on from here, if I can try a bleed/fresh oil first.
Thanks in advance.
« Last Edit: October 17, 2010, 09:53:16 PM by Nortstudio »
1976 CB550K...in progress
1975 CL360...eventually custom
2009 Husqvarna TE610
a blog about wrenching in Brooklyn, NY
“Success is dependent on effort.”
~Sophocles
Offline haggeo
Re: Yep...new guy, 'nother brake question
« Reply #1 on: October 17, 2010, 07:30:02 PM »
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #2 on: October 17, 2010, 07:33:36 PM »
Thanks so much!  Videos even better.
~Sophocles
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #3 on: October 17, 2010, 09:17:51 PM »
Does the super tight brake lever sound like it's just a bleed issue, or should I go ahead and buy a MC rebuild kit to be safe?
Thanks
« Last Edit: October 17, 2010, 09:52:49 PM by Nortstudio »
~Sophocles
« Reply #4 on: October 18, 2010, 02:14:46 AM »
I think you should really work on getting the bleeder valve out so in the future you will be able to do a proper bleed. Use penetrating oil and heat,be patient. If the bike has been sitting for any long period your caliper should come off and be split and cleaned,pads and piston hang up and cause a bad feeling at the handle and brakes drag.You will get a better assesment on the master while doing the first chore.
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #5 on: October 18, 2010, 05:08:21 AM »
It hasn't been sitting, but the owner obviously let some things go. The brakes do stop me, I just want to make sure I'm getting the most out of them. The hard lever just doesn't seem like "the most."
Sounds like good advice. I will work on the blessed, take things one at a time. Don't want to get ahead of myself.
What heat source do you use?
Thanks.
~Sophocles
« Reply #6 on: October 18, 2010, 05:29:37 AM »
On something like that I would use just a hand held propane torch. Aluminum expands quicker than steel,just some moderate heat to help break the bond and not damage the rubber seal or aluminum.
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #7 on: October 18, 2010, 05:37:29 AM »
Thanks so much for your help.  I have a new bleeder valve on the way.  Wish me luck!
« Last Edit: October 18, 2010, 05:42:29 AM by Nortstudio »
~Sophocles
Offline Toxic
« Reply #8 on: October 18, 2010, 06:52:34 AM »
for what it's worth ...  the most frustrating thing I tried to do on my bike was rebuild that effing master cylinder.  The best thing I did was buy a brand new one for $69.00.
