Author Topic: Order of disassembly  (Read 1721 times)
Offline CA Joe
« on: October 18, 2010, 08:30:17 PM »
We all feel we are reasonably mechanical  but most of us have probably at least once fought our way for a week through a project only to have someone later inform us that it was a 15 minute job if only we had taken a few minutes to remove the left handed levitation adjustment handle.
So before I start disassembly,
Is there a particular order in which one should completely disassemble a 750 4
Thanks
CA Joe
Offline the technological J
  • deliciouso!
Re: Order of disassembly
« Reply #1 on: October 18, 2010, 08:35:46 PM »
i know that the frame removal from the engine is alot easier if you wait till u have a bare frame and not a rolling chassis other than that.... just go at it is my approach
94 ST1100..Gone
72 750 K2 Stay tuned!
Offline CycleRanger
  • No comment about being an
« Reply #2 on: October 18, 2010, 10:35:33 PM »
Is there a particular order in which one should completely disassemble a 750 4?
Drain and remove the gas tank, the side covers, the battery, and the seat and place them in a safe location.
Drain the oil from the engine and the oil tank.
After that if it were me I'd start by removing the back wheel and work my way forward from there.
Remember to take lots of photos to help you remember where things go......  It really helps.
Offline CA Joe
« Reply #3 on: October 19, 2010, 10:04:48 AM »
Thanks guys, I appreciate that and it goes along with what I had researched so far. I'd just rather ask if there is some document out there which gives the order so that I don't start to remove something which then complicates the whole remainder of the job. This is my first experience with Hondas and I've got three to disassemble.
If anyone else has any "GOLDEN" tips please chime in.
Thanks again
CA Joe
« Reply #4 on: October 19, 2010, 10:50:38 AM »
I would loosen the rotor bolt while the motor is still in the frame and the chain is still on, so you can keep the motor from turning by putting the trans in gear and applying the rear brake.
Offline haggeo
« Reply #5 on: October 19, 2010, 11:18:31 AM »
get the engine as clean as possible before opening it it up, wish i would have done that :'(
if you are working solo take the front wheel and rear wheel off before laying the bike on it's side, much easier.
organize everything you remove and label it. i have tons of now random nuts, bolts and doo dads that i have to figure out :'(
Offline drones76
« Reply #6 on: October 19, 2010, 11:51:34 AM »
Not a specific order but a method.  Get lots of small and medium paper bags.  As you disassemble, place the parts in the bags and write down lots of info about what is in there.  As you put stuff in there, also write a number on it that indicates the order in which stuff was bagged.  Go pretty much in reverse when re-assembling.  Larger stuff in boxes.
I also have a whiteboard in the garage for random notes and things that this dimming gray matter does not want to forget.  And lots of pictures.  Digital cameras are great.
One other rule I have for myself is that I do not put anything in a bag or box that is not cleaned.  This way reassembly does not have to get interrupted to clean parts every time you get to another bag.  It also makes you slow down during disassembly to let what you are doing at each stage sink in.
1974 Norton Commando Roadster
1980 Goldwing Interstate
1975 Kawasaki KZ400D
Looking for a SOHC-4
Offline CA Joe
« Reply #7 on: October 19, 2010, 04:54:37 PM »
This is all good stuff guys. Keep it coming!
Thanks
Offline Accolay
« Reply #8 on: October 19, 2010, 05:11:25 PM »
+1 on many many photos.
Small cheap plastic sandwich baggies with a pen and small pieces of paper for identification in conjunction with digital photos. Tie the baggies closed and put together in a secure box or tub with a lid so they can't get lost.
You may find your life gets busy or whatever and can't get to the project for a while. Very handy to have them all together and labeled when you come back many months later.
1977 CB550F
Offline CycleRanger
« Reply #9 on: October 19, 2010, 06:07:01 PM »
Words of wisdom.  I have the better part of a '67 Mustang in baggies, boxes, and plastic cottage cheese containers.  I took it apart three years ago....
Offline mystic_1
  • 1970 CB750K
« Reply #10 on: October 20, 2010, 04:53:06 AM »
Wherever possible, when you remove something, screw the bolts etc back into their original holes.  Nothing's more irritating than having to go through a pile of bolts with a caliper and a parts book trying to figure out which bolt goes where.
mystic_1
- John Augustus Shedd
Offline CA Joe
« Reply #11 on: October 26, 2010, 02:00:27 PM »
Thanks gentlemen I appreciate the input
Offline tango911
« Reply #12 on: October 26, 2010, 02:03:31 PM »
nice thread
CURRENT STABLE:
1969 Honda Dream 305 (black)
1974 Mach III kawi 500 smoker
K2 (project)
K2 Original fixer up
K0 original fixer up
2006 CRF250R
Offline tmac
« Reply #13 on: October 27, 2010, 07:28:11 AM »
zip lock bags and a sharpie. put parts in bags and label with sharpie. It makes life a hell of a lot easier going back together!! Simple green works great at degreasing ! Good luck, Just got mine all back together down to the last bolt! No left over parts!!!
