Can't figure this either... all the other rocker cover bolts are described in the partsbook as "flange", UBS is only used for these two and for the bolts that hold on the crank rotor & primary gear. Maybe it's some sort of description for high tensile. I've rebuilt plenty of these motors & never given it a thought before, so I think you'll get away with just sticking to the right length.
