Well here is a pic of the 1975 CB750 I just picked up. I am going to tear it apart and rebuild it with the help of you guys on here. I have never built a street bike..only experience has been with dirt bikes.
Going to pressure wash some of the grunge off and get it ready for disassembly.
First question. It has an oil leak from one of the gaskets.. looks like from the lower cylinder head gasket. I want to put on new gaskets to fix any leaks. The bike has 19k miles on it. Should I do a rebuild on the motor at the same time?
I read a couple of threads on here and looks like I can pick up the parts needed for about $300, but should I do all this or can I just replace gaskets?
Full gasket set (CycleX, $59.00)
Set of Piston Rings (Rusty Riders $30.00)
Cylinder Hone (buy the tool to fit your cordless drill, around $10.00)
Heavy Duty Tsubaki Cam Chain (Z1 Enterprises $28.00)
OEM cam chain tensioner, wheel, and guide (Z1 Enterprises $61.00)
Engine seal set ($20.00 from Rusty Riders)
New OEM Primary Chains (Terry Quail, $70.00 per set)
New NGK Spark Plugs ($10.00 from your nearest auto parts store)
New points ($10.00 from Rusty Riders)
Engine Enamel ($10.00 from your nearest auto parts store)
![](http://i19.photobucket.com/albums/b175/DavinEberhardt/side.jpg)
