Author Topic: 750F forks ?  (Read 1464 times)
Offline 78 k550
750F forks ?
« on: October 24, 2010, 06:58:51 PM »
Hey All,
I can't remember if I took off my fork ear to see if any rust is under there. I have a set of perfect 77 550F forks I know the lowers are different but are the uppers the same. The uppers off the 550 are like new.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Re: 750F forks ?
« Reply #1 on: October 24, 2010, 08:03:54 PM »
Is there a question in there? about a 750.. ???
Offline steam-powered man
  • Not the eggman, Not the walrus, I am the
  • Where are you going? I was going to make Espresso
Re: 750F forks ?
« Reply #2 on: October 24, 2010, 08:48:27 PM »
here's an answer to a question, but not sure if you asked it:  according to bikebandit.com, the fork tubes for a 77cb550k and 77cb550f have the same part number.  pls double-check of course, capice?
searching for a dr350se
Offline 78 k550
Re: 750F forks ?
« Reply #3 on: October 24, 2010, 09:25:54 PM »
Sorry ? was will the uppers from the 550F fit the 750 if I needed to use them.
If the same part # looks like i'm in.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Offline 78 k550
Re: 750F forks ?
« Reply #4 on: October 24, 2010, 09:30:25 PM »
sorry more of a 550?
ok here ya go.
Are the 750 upper fork tubes the same as the 77 550f uppers.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Offline Alan F.
Re: 750F forks ?
« Reply #5 on: October 25, 2010, 06:08:39 AM »
No, 550 tubes are shorter than 750 tubes.
