Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
what I was trying to point out, the duration on the card, is quite long, but measured at .050 the duration is quite close to a megacycle.FWIW, The RC cams, at least some.. were ground by Engle.. I think they were around a little while.... I do wonder a bit about the big clearance, and suspect it is partly for lubrication..
Make sure you change the cam chain for sure, regardless of witch cam you use.
