Like others have said, it's not terribly hard.
Make a decent stand so the engine is supported level upside down, wood is fine.
Get a set of oil seals, it's worth replacing them while you have it apart.
On reassembly, test fit it at least once to make sure you can do it properly. I like to test fit all the bolts as well to make sure I have the correct lengths going in the correct holes, and I even drill a piece of plywood with the rough bolt pattern to hold the bolts so they don't get mixed up.
Then coat the mating surfaces with 3-bond type 4 or equivalent semi-hardening sealant, you only have to coat one side of each joint. You want a thin coating so that not too much gets squeezed out, too much inside can form loose lumps that shouldn't be floating around in the oil.
You have about 30 minutes to assemble it once the sealant is on so don't be in a mad rush.
Tighten the bolts in sequence. The bearing bolts are the most important to tighten and torque in sequence, the rest pretty much just hold the cases together so they don't leak but a cosswise sequence is still worthwhile.
Check that the transmission shifts through all the gears before you button up the side cases and reinstall the engine.
