Thanks all for your warm words.
I do not quite know what to do? Maybe Call the fire department?
Some of the combustion chamber. All of these principles, which are known to relate to traditional constructions.
Some of the combustion chamber. All of these principles, which are known to relate to traditional constructions. But even such a chamber as Riccardo Comet has a large surface area. In addition, of course, depends on whether it is petrol or diesel.
Suppose that it is petrol. So they can theoretically be formed detonation / but only in theory. In practice, this is not my chamber parts hotter than 300 degrees Celsius. Even the spark plug can be blocked Immediately after ignition, the suction piston.
All of these pistons cooled by oil spray can, as in Crecy.
Therefore, it will be possible, with complete absence of detonation , obtaining the compression ratio even 1:18, if it would be correct.
Or use of gasoline is not octan.
Wild very easy way of changing the compression ratio, maybe we can change it, even to a large extent depending on the needs.
I got in his prototype, due to mechanical forcing cargo. because I am too big turbulence did not allow a spark to the spark plug .
spark between the electrodes was not possible to entrust the creation of ionized needed spark to jump.
So great was the air velocity in this new "dymnamic" combustion chamber, which is probably more and more new laws may have.
Andrew
