Author Topic: Spark plug hole threads are stripped. What do I do?  (Read 22599 times)
Offline Dr. Honda
« on: October 28, 2010, 09:52:37 PM »
HELP!
My threads for my spark plugs are stripped on the engine.  I've never had plugs in it, it did not run when i got it.  Now the motor has been rebuilt, and I put it back together, well, I was about to degrease it to prime and paint and I was screwing my plugs in so not to get anything in the engine, the last one was stripped from previous owner.  What is the lowest tech, non-honda repair shop way to fix this.  I really dint want to take the motor apart.  I figured run a tap in, but then the pieces of aluminum would fall into the valves.  Or either place some thin wall aluminum tube into the hole an tighten a bolt with same thread pitch and size into the hole.
What do yall think?
Offline crazypj
  • I'm brill, me
Re: Spark plug hole threads are stripped. What do I do?
« Reply #1 on: October 28, 2010, 10:11:14 PM »
You can get 'Recoil' which is pretty much same as Helicoil but cheaper.
Pep-Boys, Autozone, et.al. about $35.00.
 Why wasn't it fixed while engine was being re-built?
If it wasn't checked closely enough to see stripped thread, I wouldn't trust rebuild
Offline camelman
  • Man... Myth... Legend
« Reply #2 on: October 28, 2010, 10:16:45 PM »
Take the head off and do it correctly.  Don't use a cheap helicoil either.  The sparkplug will not seal against a cheap helicoil, and you will get blowby every time that cylinder compresses and/or fires.
You might be able to reuse your cylinder head gasket if you haven't heated it up yet.  I'll let others weigh in on that though.
Camelman
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
« Reply #3 on: October 29, 2010, 01:14:36 AM »
the head gasket will be ok,pull the head and fix it or get it fixed.
Offline katmol
« Reply #4 on: October 29, 2010, 01:32:54 AM »
If the bad threads are not very deep you can get a tool called "BackTap" that works like a charm. I just bought one on Ebay for $10 and it worked great! I repaired plug hole #3 with the head on the motor and the motor in the bike. You insert the tool all the way into the plug hole then turn the knob on the back of the tool, this makes the cutting head expand to fit the plug threads. As it snugs up, carefully keep checking that the threads are aligned by screwing it back and forth a little each time you tighten it. Once it's positioned you just carefully unscrew it and it repairs the buggered threads as it comes out. It good to put a little grease on the end to help with the friction and it helps to hold any cuttings. There should be very little cutting involved since you are just straightening out the threads. Worked great for me. Kept me from pulling a motor.
HELP!
What do yall think?
'74 CB750K Tracy Project
'76 "Modified" GL1000
'77 CB750A Blue
'77 CB750A Red
'79 CM400A Hondamatic
'81 CM400A Hondamatic
"Gone but not forgoten."
'76 CB750A Muscat Green
'70 CL450 Scrambler
'72 CL350 Scrambler
'75 CB750K Stock
'78 750K Black Dresser
« Reply #5 on: October 29, 2010, 01:43:03 AM »
if the threads are so stripped that a plug wont tighten up remove the head.,you wont rebuild threads by trying to retap them like that.
Offline katmol
« Reply #6 on: October 29, 2010, 01:45:37 AM »
That is correct if they won't tighten up. But if they won't screw in, it certainly worth a try I would think.
'77 CB750A Blue
'77 CB750A Red
'70 CL450 Scrambler
'72 CL350 Scrambler
'75 CB750K Stock
« Reply #7 on: October 29, 2010, 03:54:22 AM »
if they they wont even screw in,reaming them is only going to result in tears,pull the head.Dr honda states the threads are stripped,give it a go and pull the head later.
Offline cookindaddy
  • I sure love this bike!
« Reply #8 on: October 29, 2010, 04:36:51 AM »
A helicoil (or a reputable competitor and there are several) properly done is as good as the original. Any engine re-builder can put them in for you. I have two in mine. The compression is great and the bike goes like hell. You should pull the head.
George with a black 78 CB750K (in Lion's Head, Ontario, Canada)
« Reply #9 on: October 29, 2010, 04:41:10 AM »
you can be as carefull as you like,some chips WILL fall into the bore,pull the head.,they might just all blow out on the next fire.then again they might not.
Offline nokrome
« Reply #10 on: October 29, 2010, 07:35:53 AM »
http://www.timesert.com/ makes a product that is specifically designed for spark plug holes, the kit is a little spendy but it is by far the best product for this application imo.
   oh, do yourself a favor and take the head off before you attempt the repair, its really not that big of a deal
Funny thing about regret is...... its better to regret something you have done than to regret something you haven't done.
Offline katmol
« Reply #11 on: October 29, 2010, 09:38:38 AM »
They're right, I'm wrong. Since the motor's out do it right, pull the head. Sorry.
'77 CB750A Blue
'77 CB750A Red
'70 CL450 Scrambler
'72 CL350 Scrambler
'75 CB750K Stock
Offline crazypj
  • I'm brill, me
« Reply #12 on: October 29, 2010, 11:12:07 AM »
I would only use copper plated Timesert inserts, they are designed for spark plug hole repair.
 The plugs don't seal on the threads so it doesn't matter what type of insert you use.
 Don't use any threadlocker, that's only used by cowboys who screwed up and are trying to 'glue' inserts in place
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #13 on: October 29, 2010, 11:27:16 AM »
If you use a tap coat in thick grease. this will catch 99% of the shavings.
Someone wrote:
" The sparkplug will not seal against a cheap helicoil, and you will get blowby every time that cylinder compresses and/or fires"
Say Wha? I tapped and helicoiled my ford truck and I've put 10,000 hard miles on it no problems since. Including a trip halfway across the US and Canada @ 14 hour days and towing my boat 1000 miles roundtrip over two mountain passes each way. And the timesert is nothing more than a fancy over priced helicoil (same idea same result) but at 10X the cost.
The one good thing is the SOHC4 head is relatively easy to take off, unlike my F150.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline the technological J
  • deliciouso!
« Reply #14 on: October 29, 2010, 11:38:01 AM »
what kind of bike? you can get a new head gasket( if need be) for a 750 at cyclex for 8 bucks
94 ST1100..Gone
72 750 K2 Stay tuned!
Offline sangyo soichiro
  • Tuck
  • ☢ the atomic playboy ☠
« Reply #15 on: October 29, 2010, 11:38:11 AM »
Just a FYI from a former tool and die maker...
(This is just an aside, and not necessarily anything to do with Dr. Honda's problem.)
You guys are talking about chips from the tap falling into the cylinder.  There's a kind of tap called a "roll tap" that pushes the metal (as opposed to cutting it).  It makes for a stronger thread, but the hole being threaded should be a softer material (like aluminum).  Here are two pictures so you can compare the two types of taps.
Roll tap (forms the thread by forcing the metal outward):
Regular tap (cuts the thread):
1974 CB 750
1971 CL 350 Scrambler
1966 Black Bomber
Too many others to name…
Offline cookindaddy
« Reply #16 on: October 29, 2010, 12:31:08 PM »
Interesting about the roll taps. I'd never heard of those. I haven't started looking yet, are they readily available? Would they be good for chasing threads to clean them up? In that case I'd try to find M6 and M8 since that's 90% of the bolts on the SOHC4. I have been running a regular tap through rusty threaded holes with good success although some here say that you shouldn't use a tap for that. Those would be mostly steel threads.
Offline katmol
« Reply #17 on: October 29, 2010, 12:37:05 PM »
If you're going to try a tap please looking into to the Back Tap.
'77 CB750A Blue
'77 CB750A Red
'70 CL450 Scrambler
'72 CL350 Scrambler
'75 CB750K Stock
  • Tuck
« Reply #18 on: October 29, 2010, 12:40:21 PM »
Yes, I think they are readily available, although I haven't used one since my machinist days so I never went looking for one.  I suppose if you're just chasing threads, these would be good, but I'd try to make sure there's no dirt and junk in the threads.
1974 CB 750
1966 Black Bomber
  • Tuck
« Reply #19 on: October 29, 2010, 12:44:45 PM »
1974 CB 750
1966 Black Bomber
Offline katmol
'77 CB750A Blue
'77 CB750A Red
'70 CL450 Scrambler
'72 CL350 Scrambler
'75 CB750K Stock
Offline Dr. Honda
« Reply #21 on: October 29, 2010, 05:14:27 PM »
It's a 72 cb500 k1
Offline Dr. Honda
« Reply #22 on: October 29, 2010, 07:37:21 PM »
Kind of a silly question i think,  but I know i use an 18mm socket to tighten my spark plugs.  The repair kits for the threads are different sizes, i guess this means i need one for 18mm plugs, right?
« Reply #23 on: October 29, 2010, 07:44:08 PM »
The socket size is not the same as the thread size. (Sorry, I don't know the thread size off the top of my head, but I think it's about 12mm.)
Offline crazypj
  • I'm brill, me
« Reply #24 on: October 29, 2010, 11:17:29 PM »
Roll taps come with Timeserts.
 If it isn't lubed properly you will be in much worse shape
