Author Topic: Sandcast #97 restoration  (Read 226044 times)
Offline lucky
Re: Sandcast #97 restoration
« Reply #350 on: March 02, 2012, 08:21:06 AM »
I see no comments about my bearing clearance so I guess that’s a good thing.  :)
So I thought I’d made up my mind about doing the micro welding but in second guessing myself I decided to do a little more research.  There are two choices for rods, 4043 and 5356.  I had my welder use those materials on my test cover so I could compare.  Here’s after welding.
Here’s after sanding and polishing.  Not a great job but enough to see results.  It took about 20 shots to get one that showed a difference and you still have to hold it just right to see it but there is a difference.  The 4043 and 5356 look very similar in the picture but the 5356 is definitely shinier.  Between those two the 4043 would be the best choice.  That’s what the micro welder used to test on the alternator cover.  But the area that was welded with rods made from the cover (somewhere in the circle) is barely detectable.  I’m not even sure that I can see it with the naked eye.
So I am going to have my welder do it with the similar material home-made rods.  He said he would see how it goes and could do most of it but he may want to stay away from the lettering.  I figure at most there are two spots in the narrow band just below the “MADE IN JAPAN” that I could finish with the micro welding where it won’t show.  Here are the rods I made up.  It was hard to make them much smaller than 1mm square because they are very brittle.
I realize I’ve been pretty anal about this cover.  I’ve even been annoying myself but this smooth logo, thin-lipped cover was only used on the first 342 engines.  So I want to get it as good as I can.  The bad part is my welder just took on a big job and won’t be able to get to it for a couple of weeks.  I’ll have to find something else to work on.  Only about a million things to pick from.
The 5356 is better if the part is to get anodized. It leaves a better look between the parent material and the weld material. I would just use the 4043 because
it will blend in with the cast metal. The 4043 is made for general repairs.
Offline markb
  • When I finish my current project I might be a
« Reply #351 on: March 31, 2012, 01:41:11 PM »
I’m way over due for some updates.  Some of you may be wondering about my alternator cover welding repair.  Shortly after I gave the stuff to the welder he had a death in the family and has been spending all his time settling the estate and getting a house ready to sell and hasn't been taking on any welding jobs.  I talked to him last week and he promised he’d have it done by the end of April.  I know, it’s been months, but I really don’t want to have anyone else do it and I don’t need it yet anyway.
Also I’ve been busy working on trying to make some reproduction mirror stems.  Seemed like any easy project but it’s taking longer than I thought it would.
I finally got the chrome plating back.  It was quite a load since I had some stuff from 97 and 1553.  Overall I’m quite pleased with it.  I’ll never be totally happy because I’m too picky.  If anything some of it is too good, in other words, better than original as far as the finish before plating.  But I don’t think I’ve ever seen restored chrome look original and everyone seems to be OK with that.
I did duplicate parts like fenders so that they could compare fender them for straightening but I threw in some other duplicate parts too.
The plater seemed to do the best on the bigger stuff like the wheels.  Except for being over done they look great.  They were in pretty rough shape.
My biggest complaint is the bolts for the brake disc.  There’s no sharp edges left on the hexes so in my opinion they’re way overdone  Supposedly they were too rusty and they had to polish them much to make them look OK.  I’ve got some nice original ones that I might have to “borrow” from one of the other bikes so it’s all good.
Obviously I don’t need any of this yet so I just wrapped everything up real good and put it away for now.  My zinc should be done soon.
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
« Reply #352 on: March 31, 2012, 01:45:43 PM »
I'cw been following this, but I lost track of the zinc plating post. I probably wasn't too interested at the time, but now I am.
Can you give 20 words or less (or more) on what you're doing there?
PS: the chrome looks great, and that's coming from a chrome whore.  :D  I know the guys in VJMC talk about the fact that its hard for a chrome shop to dumb it down to production quality. I remember that the part of the rear fender that is hidden under the seat, on an OEM bike, is pretty poor. Factory would only polish what absolutely had to be polished.
« Last Edit: March 31, 2012, 01:48:06 PM by MCRider »
Offline markb
« Reply #353 on: April 01, 2012, 08:43:15 AM »
To get good zinc plating I first clean and degrease everything.  I run a tap in the nuts and threaded parts and a die on all the screws and bolts.  Then I wire brush or bead blast them (mainly the heads, especially the pan head cross screws).  Some of the nuts and more common washers I buy in bulk and throw them in so they match.  The plater also cleans and strips them but they will only do so much.  It's a lot of tedious work but the finished product will be much better.  Sorry, I think that was more than 20 words.
« Reply #354 on: April 01, 2012, 09:32:07 AM »
Thanks, that's what i wanted to know.
Offline markb
« Reply #355 on: April 29, 2012, 09:44:58 AM »
I guess this is a case of 1 step backwards and two steps forward.  About a month ago I decided that the painting I had done last year was too shiny.  I had my painter do some experimenting and after looking at some samples decided to have everything repainted.  I tried taking some pics to compare old and new.  It’s next to impossible to get a good shot of something black.  But you can kind of tell in this pic, the new is on the left.  In person I think it turned out fantastic and will look much more correct.
Offline CycleRanger
  • No comment about being an
« Reply #356 on: April 29, 2012, 10:39:59 AM »
Admirable attention detail! :)
The one on the left does look better.
Based on my experience stripping old parts I'd say a lot of the small parts were originally dipped, a common industry practice back then, (and still today) and it's difficult to duplicate the exact finish with spray.
Offline SoyBoySigh
« Reply #357 on: May 20, 2012, 05:36:07 PM »
With all of the effort that's being put into these projects by all of these different people, somebody ought to look into having patterns collected for making reproduction parts that are correct to the type.
It would certainly be a special challenge for say, the folks who are making reproduction Vincents or MV Agusta 350 fours and the like, if they could make a proper sand-cast replica that all of the experts couldn't tell from an original. I know, it would take a hell of a lot of the mystique out of the whole thing, a reproduction part wouldn't have the same "soul" or whatever. Maybe they could have a small maker's stamp just so that people would know the difference, so that when they're doing their whole "touch-stone" thing and connecting with the past through this amazing time-machine of a motorcycle, they would know what's actually transporting them back in time, and what's just giving them a cool retro vibe. But yeah, at the very least, the bolts and screws and stuff, ought to have some reproductions made.
Because the real goal here is that ALL of the original bikes be put back to original condition, then ridden hard and put away wet for thirty-forty years, and re-built all over again! To THAT end, it behooves one to take decisive action. Because let's face it, it will be hard to find even the most anal-retentive kids of the next generation who'd be motivated enough to even read through some of these threads, unless it relates somehow to what they're trying to do with their '05 CBR restorations, so why not make it a little more "user friendly" for the next generation of Sand-cast restorers? You know damn well, it would be extremely lucky if all of the bikes are restored in the next fifty years, all all the more less likely people would feel inclined towards it in the first place, come ten or twenty years down the road. So, the more of these parts that have been oh so lovingly and carefully measured and restored and compared for finish quality etc, that they be reproduced in as authentic a practice as possible.
Perhaps reproduction dies for stamping the heads of these bolts could be fashioned? I dunno WHO, but certainly NOW IF EVER would be the time when a company would feel economically motivated. I doubt very very much that Honda itself would EVER feel the need to help out the restorators out there, they have such a crappy record with helping people with spare parts in the first place.
In my own experience, I had a '69 CB100 when I was sixteen, back in 1990, and when I asked at the parts counter for just a peep at the parts fiche and for help with getting parts for it, I was lied to point blank about the whole situation, and I think their reasons for doing such was that an inherent conflict of interest exists when dealerships are responsible for the warantee work and all of that rot, let alone keeping vintage machines on the road. The primary motivation for a dealership is selling more new bikes. The parts and maintenance dept should be a separate entity, taken on by the parent company itself, not subordinated to the local franchise dealerships. As such, the whole business model has been screwed from the get-go, long before these "early" bikes were even made. I've heard some real nightmare stories about dealerships in the early-to mid sixties, where Honda left them with ridiculous recalls to deal with, and more work being done in the local shop than ever went into the bikes on the assembly line itself.
But right about NOW would be the best financial incentive, and it would make life easier for those folks who'd ALSO like to restore their bikes but who may not be quite as anal as you are.
So, what I'm thinking is, maybe some of these very rare and special parts that each individual owner-restorer has his hands on, whether they be rubber damper blocks or gears from the transmission, or hubs or bolts or ... whatever, could be cast in a dental-silicone or whatever it's called, just a good solid supported mould, maybe a chunk of plaster or even a ceramic mug to keep the whole project time to a minimum, anything size appropriately for the part, then the wax or silicone #$%*, supported by the hard object be it a mug or a plate or whatever, and then somebody ... NOT ME ha ha, could collect some of this #$%* together, hell I'd talk to some kind of specialy fasteners manufacturer, or even somebody who's a big player on the sand-cast parts supply end of things, so that those most rare and unusual parts could be made rather than just a substitution of later edition parts be they die-cast or late era sand-cast parts. There are already people out there making reproductions of the magnesium twin-leading shoe hub for the CR750, and the dual disc front hub was put into reproduction by aftermarket people a long long time ago (Though I sure don't understand why people wouldn't just use the gold-wing hub for that application....) so, despite the high cost of the CR rear drum, given the different materials I don't think it would have to be outrageously priced.
Then, perhaps even using mostly the same moulds with perhaps a different center insert, as was probably the case with Honda's production casting of long ago, the no hole and two hole and four hole hubs could be available to all, and what with all of the information gathered then people would know, or have some good indication, whether and which of these hub types was appropriate. I mean, IF they wanted to do up an authentic reproduction. I'm sure it would piss off the guys who've bought up all of the NOS stuff. Some of them invested in buying up every last NOS part available more than ten or fifteen years ago, but hey I'm sure they've made their investment back by now! Ha ha. Really though, there's stuff even THEY can't help you with.  I'm sure that if it was a re-call part, unless a shop was truly neglectful of their bottom line or made a mistake, or an employee raided the trash bins, that none of that #$%* is even AROUND anymore whether in the stocks of the NOS specialists or the Honda shops they cleaned out years ago. It doesn't seem like Honda's sueing any of the people making reproduction Cub parts over in Asia. Hell, I'd bet that some of THOSE guys would be just the people you'd wanna talk to about making this stuff.
But the important thing, is that whether or not anything like that would ever be possible, hinges on just how anal-retentive you get with these original parts. And I don't think anybody on the whole sand-cast scene would make fun of you for going even further than you've already done. You know what they say, you can polish something, you can restore it, etc. But you can't put it back to original. The patina is one thing on a coin and another on a bike part, yeah I realize that. But I'm sure that something could be gleaned about the finish processes by some kinda chemist lab, forensics lab, etc. Maybe if somebody ever murders anybody else over sand-cast parts ... somebody famous, hopefully a case with some racial component so that the media gets sucked into it like another whole OJ mind-#$%*, THEN the most extensive forensic work would be done on these things. Of course, most of it would be bull-#$%*. Ha ha. But still, if there's somebody could take a look at some of those parts BEFORE you run a tap and wire brush all over the things, maybe take some micro-macro photos, some sampled flakes of zinc or chrome, then the best understanding of the correct finishes at different phazes of production could be understood.
That's the type of thing that's being done in the collectors' fire-arms side of things, and most of those lugers don't hold a candle to these bikes so far as value right now. Fact is, a lot of fire-arms restorators or evaluators know a heck of a lot about metal finishing processes, especially obsolete stuff. Not too sure whether there's much known about the stuff from this period of history, I'm sure they know a lot more about 1930s or'40s Japan, than the 1960s....
It also seems like the big problem with the sand-cast scene is a lack of communication between western collectors/hobbyists/restorators and Honda itself, or even the former employees of Honda's manufacturing plants. You might recall the whole "controversy" about vaccuum die casting vs sand casting vs gravity die casting etc etc. That was settled, well for SOME of us I suppose, by a conversation with a former casting line employee. Or was it somebody who worked next to the casting line building? In any case, the whole Western scene seems too preoccupied with the likes of Dick Mann or Freddie Spencer (I'm a DOHC guy, actually. My interest in the sand-cast is for the sand-cast tribute DOHC build I'm working on. Sort of like a "Dream-DOHC", in more than one sense of the word....) than they wonder who the first guys to ride the bike were, on the secret factory test tracks. But I'm sure that you sand-cast nuts, like me, are a lot more curious about THOSE guys, than you care about the whole marketing side of things, which is what the early competition track riders were doing. Marketing. 'Cause the development was already DONE. Right?
Just my two cents.
Kudos on your exhaustive efforts for these bikes. Your spread-sheets seem like a fantastic resource. I only suggest that - The next opportunity you have to measure some rare, odd, original parts? Go for as complete a "measurement" of them, be it chemical analysis or even just sampling for later analysis, (From what I gather, some Zinc plating type processes were proprietary secrets?) down to a good detailed bolt-head moulding using a good quality material. They use that dental silicone crap to replicate the labia or fore-skins of porn-stars for the boutique sex toys people seem to buy record numbers of. I only mention it, 'cause that's the first place I ever heard of some of these materials. Ha ha. When my ex-wife worked in a love-shop when we were in college. Damn, I could tell some stories! Ha ha. But yeah, from what I gather they're very dimensionally stable, and they pick up an incredible degree of detail. A lot of the bodywork parts seem to be defined by the number of holes or this or that impression, like the two dent vs four dent undersides of gas tanks. Well, it wouldn't surprise me if a selection of gas tanks were measured with ... either one of those ruby-sensor deals, or maybe some kind of lazer or x-ray photography technique, then there might appear to be different versions or shapes of say, side covers or air-cleaners or gas-tanks, fenders etc, that are not immediately apparent to the naked eye, or the untrained eye. There are plenty enough of these bikes constructed side by side, as in your case where you've got three or four bikes for comparison. But seldom are they consecutive serial numbers, or even from the same series sub-unit, so how then do we know for sure what's out there that could be radically different? Just a few guys out there, like yourself, pouring over photographs and fondling every part or bike that you can lay hands on. The more accurate numerical data collected, such as your spread-sheets, the closer to perfection, the closer to a person being about to pop on the scene with "I just found # 34XX in my uncle's basement. Is this a sand-cast?" or even "Is this a CB750?" ha ha, and they could just connect with the right people and be able to obtain pattern reproductions of every correct part they'd need to put the bike back to as-new condition. Maybe with a couple dozen secret silver-smith type stamps on the new parts.
Anyway, I'm talking around in circles. Just high. Sorry.
Oh, and by the way, by far the best thing I gleaned from this thread was, in addition to your advice about pre-plating-preparation, the stuff about the home-made welding rods. I've been looking at modifying DOHC parts, (rear-set plates, valve covers capping off tach drives, etc etc) and was unsure which aluminum welding rod to use and how to determine which to use for which application. Your info hit the nail on the head. Though it's likely Honda changed their alloy formulae over that thirteen-fifteen year period, yours is a good method of determining like-materials.
Again, kudos.
-S.
« Last Edit: May 20, 2012, 05:40:34 PM by SoyBoySigh »
Offline SoyBoySigh
« Reply #358 on: May 20, 2012, 05:42:45 PM »
Oh, and by the way, about the "no-hole" hub. I count forty-nine holes.
-S.
Offline Roach Carver
« Reply #359 on: May 20, 2012, 05:48:38 PM »
Holy cow. I almost read that.  ;)
Offline Old Scrambler
« Reply #360 on: May 20, 2012, 07:24:39 PM »
#97 is attracting more attention!
BTW...........I have made a reproduction special bolt for the HONDA CL72-77 models and have sold them to HONDA employees in Japan. The problem today is that most of the nuts, bolts, screws and pins have been reproduced to meet a percieved price point........I have yet to find EXACT reproductions.......even when sold by HONDA.
Keep up the good work Mark.....................and also note this for the chrome shop...........I try to take a sample of what each piece should look like and I give them the OD for critical parts such as handlebars and axles.  I found one shop that added 'whitener' to his chrome tank to replate my NOS pipes without doing any prep work other than stripping the old scratched chrome.  They look very good and do NOT have a mirror finish.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline fastbroshi
  • Puppet
« Reply #361 on: May 20, 2012, 08:36:12 PM »
not to get off on a tangent or anything, but what's so special about this CB72-77 bolt?  Got a pic?
Just call me Timmaaaaay!!!
« Reply #362 on: May 21, 2012, 05:34:20 PM »
Its the extended bolt that holds the two exhaust pipes on the Scrambler models to the frame.  I took my only original and had a local shop do a CNC reproduction.  Then I sanded the end to match the sandpaper factory finish and had them chromed.  The chrome shop polished my sanding marks......but its the only reproduction around so I have sold about 80 units at $15 - $18 each plus postage.
Back to Mark's project..........
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
Offline markb
« Reply #363 on: May 24, 2012, 11:56:42 AM »
Yes, I wish I could.  Too busy with work for one.  Then I'm into my boating and fishing season.  Then there's weddings, graduations, grandkids, other projects....
Progress will be slow for a while but I'm going to try to budget a little time each week to do something, anything.  ::)
Offline SOHC Digger
  • I'm not an
« Reply #364 on: May 24, 2012, 10:28:23 PM »
Whoa! Whoa! Whoa!  Way too many words.
I was, like, "What?"  And then I was, like, "Huh?"
And then, well, I got a little bored and...
Something about clutches?
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #365 on: May 25, 2012, 05:42:00 AM »
That's how I roll with these old Honda restorations. A bit a day will keep the bike and you happy. And after a few months the fun will really begin, riding it!
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
Offline lucky
« Reply #366 on: May 26, 2012, 10:14:34 PM »
Those 1969 carbs are so easy to work with!!
« Reply #367 on: May 27, 2012, 08:56:26 AM »
 SoyBoy..look up CMM machine.. only problem is who pays to  do that?
Offline markb
« Reply #368 on: June 20, 2012, 09:29:13 AM »
I finally have my zinc plating back, most of it anyway, after dropping it off in March.  It‘s probably my fault for using this guy but I’ve had good results with him in the past and what I got looks good this time.
I haven’t found anyone in my area that will do small batches of zinc for motorcycle parts.  This guy, who does mostly chrome, does all the prep and has a buddy of his do the zinc at another shop.  Turns out he had a stroke and couldn’t do it.  I didn’t find this out until over a month after I dropped it off.  So it took a while to get the parts back and to another source for plating.  That explains why it took so long.
Now as to why I don’t have it all.  I had a small bag of parts to be yellow zinced.  The bag was labeled and in a bigger box with big parts like rear sprockets, brake arms and stays, etc.  Guess what happened?  I have yellow sprockets, brake arms and stays, etc.  ::) So they're going to redo it.  I guess it’s really not a big deal because I don’t need the parts yet.
But I have learned one thing, I’m going to quit telling people that there’s no rush on getting stuff done.
Offline MoMo
  • Ride like you're invisible
« Reply #369 on: June 21, 2012, 02:58:27 PM »
Looks good Mark, how many hours do you think you'll have sorting all that stuff?  ...Larry
Offline CB750faces.com (Lecram)
  • CB750faces.com
    • Buy High Quality Honda gauge parts online!
« Reply #370 on: June 21, 2012, 03:02:44 PM »
Step by step to the end result. I am looking forward to the final result!
I sorted out all the parts in plastic bags, based on the pages in the parts manual. That worked great when I assembled my CB750. So I had many bags, labeled E-1, E-2, E... and F-1, F-2 etc.
Offline markb
« Reply #371 on: June 21, 2012, 05:30:51 PM »
It's definately going to take a while.  I should keep track just for fun.
That's what I do too.  Then it makes it easy to work on subassemblies and where I have more than one part I can pick the best one.
« Reply #372 on: June 23, 2012, 05:37:04 PM »
I use several different 'bin' cabinets to store small and medium sized parts........they breath......unlike plastic bags!  Your sorting will go faster than mine......I took a box of MY parts for a CL77 along with a box of parts for my Brother-in-law's CB77.........the shop put them together and we are still sorting several years later.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
Offline markb
« Reply #373 on: August 22, 2012, 04:06:56 PM »
Besides being busy with my summertime boating and fishing, I’ve been distracted with another project.  One of the rare parts for the early sandies is 11mm mirror stems.  I couldn’t find any so I decided to make some repros.  They’re very similar to the other early stems but they have a few differences.  The main one is the stems are 11mm instead of 10mm.  The bend is slightly different and the nut is longer and of course has a bigger counter bore to fit the 11mm diameter.  I tried to match the original finish as close as possible but found it to be next to impossible.  They look a lot like original 11mm stems that have been stripped and replated to today’s standards.  But it’s closer to correct than the 10mm stems.  Here’s a couple of pics.
Offline Magpie
« Reply #374 on: August 22, 2012, 04:21:19 PM »
Nice work! Cliff.
