Author Topic: Fork Boots on '77 CB750  (Read 1185 times)
paradoxer
« on: November 01, 2010, 09:21:47 PM »
I'm noticing that '77 CB750K's don't have fork boots (gaiters?).  Can they be added?
Offline few-regrets
  • She asked for a little - But I slipped her the
  • Well hell...that shoulda worked!
Re: Fork Boots on '77 CB750
« Reply #1 on: November 01, 2010, 11:21:24 PM »
If your talking about a K model yes, F model no. The K uses the same lower design as the older models but you'll probably have to get some top caps (the things that keep the rubber from just floppin' around on the top - below the tree) or make something . The F (super sport) used a different design in 77 and 78. Check the '76 out - http://www.cmsnl.com/honda-cb750k-750-four-k-1976-usa_model494/partslist/F++07.html . Look at the part labelled #17 to see what I mean. Then compare to this (77) http://www.cmsnl.com/honda-cb750k7-four-usa_model14395/partslist/F07.html. The problem won't be the forks, it'll be the different fork ear design. The newer one doesn't have a lip to stretch the rubber gator over. Shouldn't be a big deal to fabricate sumthin though.
'77 Rickman-ish custom
'75 836 Screamer
'75 836 Project
'70 Project
paradoxer
« Reply #2 on: November 02, 2010, 12:23:45 AM »
Gotcha....Makes perfect sense.  Thanks for the help!
