Author Topic: Clutch lifter rod (added pics)  (Read 1204 times)
Offline DavePhipps
  • Reading the entire Hi-Perf forum
    • Hillside Technology
« on: November 04, 2010, 06:07:26 PM »
I've found that my clutch lifter rod is in 2 pieces. The fiche shows one piece. After checking around I found this thread http://forums.sohc4.net/index.php?topic=14273.25
It turns out they are supposed to be one piece. I've fitted a ball bearing between the 2 pieces and can shift now.
Does anyone know the exact dimensions of the lifter rod? I've got a friend with a lathe and a CNC machine that might be willing to make one for me.
OK I got photoshop installed so I can finally edit those huge pics down to something reasonable. I'm also adding my understead electronics setup that I inherited. Nothing to do with this post but everybody loves pics
« Last Edit: November 05, 2010, 03:13:55 PM by davephipps »
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
Re: Clutch lifter rod
« Reply #1 on: November 05, 2010, 04:31:05 AM »
its aluminium with hard steel ends,can your freind do this aswell,its no longer available from honda,id try and find a replacement,you might come across a buggered motor for cheap.
Offline DavePhipps
« Reply #2 on: November 05, 2010, 05:06:03 AM »
Thanks for the reply Dave
I'm not sure if he can do the rod out of aluminum and make the steel end caps. I'll check with him this weekend. I'll still need to know the correct lenth though.
From what I've read in the other thread is these can get compressd, so I don't trust my broken rod as a reference.
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
« Reply #3 on: November 05, 2010, 05:35:48 AM »
i wouldnt say they get compressed as such but if they get bent or the wear surfaces wear,theyll get shorter,a little,ill dig one out and measure it for you,the end in the basket is convex,the actuating end is concave for the ball,id try and find a used one.
Offline brycegp
    • 1971 CB750 "Mut-N-Chop" Cafe Project
« Reply #4 on: November 05, 2010, 01:38:13 PM »
Something is going around...mine broke today...
I just bought one for $31 (shipped) at http://www.servicehonda.com
Part #: 22850-323-000  - this is what all the related threads are saying the part # is.  and that's the one I bought.
1971 CB750K/F - El Toro
El Toro Build Thread - http://forums.sohc4.net/index.php?topic=73552.0
Offline DavePhipps
Re: Clutch lifter rod (added pics)
« Reply #5 on: November 05, 2010, 03:16:05 PM »
Incase anyone wants to know what this looks like I've aded pictures. YAY photoshop!!!
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
