Author Topic: booth built... need filters for the outlets  (Read 2455 times)
Offline superchode
« on: March 13, 2006, 06:42:10 AM »
so i threw together a paint booth yesterday: http://www.3cpu.org/gallery/750_repair/booth.jpg
i'm going to toss some hepa rated filters (furnace type filters) for the air intake to keep the dust out - but i need something less dense to pick up the paint as the air gets pulled out the outlet fans.  the furnace filters would get clogged very quickly.
does anyone have experience with this? is there something i could get off the shelf at a hardware store that would perform well in this application? definately don't want to be spewing paint into the shop - but i also want to use something generic and fairly cheap so i can get started tonight and get extra so i can swap out spent filter material as required.
Offline dusterdude
Re: booth built... need filters for the outlets
« Reply #1 on: March 13, 2006, 08:06:51 AM »
not sure exactly,but go to an auto paint supplier,they will hook you up.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
theunrulychef
« Reply #2 on: March 13, 2006, 08:28:47 AM »
We've got furnace filters for our inlets as well, but we exhaust straight outside.  Do you have the space to connect a duct from the exhaust out a window or door?
Offline superchode
« Reply #3 on: March 13, 2006, 09:08:54 AM »
no, don't have a good way to duct straight outside... plus i don't want to get paint in my fans.
paint booth supply stores online list fiberglass filters for the outlets - i was hoping to find a similar generic material that i could pick up on the way home from work tonight at a hardware store... not sure if i can get to a paint supply store after work or not.
Offline Hondell
  • Just an easy 1000 Hr. resto
« Reply #4 on: March 13, 2006, 10:01:33 AM »
Get the cheaper $1.00 furnace filters for the outlets. They have less filtering effect then the hepa type but still catch the paint. That's what I use on mine
1972 Cb750 resto- 1972 Cb750 stoplight racer- 1972 Cb750 vintage touring - 1979 CBX- 1982 Kaw GPZ- 1968 Honda SS125A
Offline superchode
« Reply #5 on: March 13, 2006, 10:07:13 AM »
alright, settled. hopefully they have ones large enough to cover most of the surface area of the floor fans i'm using. if i can get close i'll just tape off the rest.
thanks.
howardstapley
« Reply #6 on: March 13, 2006, 10:34:47 AM »
1/2 inch carpet padding for your outlets. ZERO paint will get through it, you can cut it to fit your duct size and it’s the easiest, cheapest and most available choice.
Offline superchode
« Reply #7 on: March 13, 2006, 11:41:03 AM »
hrm. interesting.
how badly would it restrict air flow across the fan?
Offline Bodi
« Reply #8 on: March 13, 2006, 04:22:22 PM »
I've used paint collecting filters that are pretty much expanded paper, hard to describe but effectively a 2" or so thick matt of paper strips that trap anything wet but pass airflow easily. We got them from a paint supply house, it came in large batts.
howardstapley
« Reply #9 on: March 13, 2006, 05:51:58 PM »
hrm. interesting.
I guess that would depend on the strength of the fans. I made a paint booth not much bigger than a shower stall (and looked like one too). I was using a combination of plywood around the base and clear plastic tarp around the top. I used an air pusher (like a shop or furnace fan) to suck air out and just drilled holes in the plywood to let air in. For both the exhaust and inlets I used 1/2 inch think carpet padding and never had a problem.
