Author Topic: F engine indentification  (Read 798 times)
Offline Trav-i
  • Has finally become an
« on: December 07, 2010, 05:59:45 PM »
This is to all the Super Sport guys out there.  I'm just trying to figure out which engine is in my F3.  I know it's not the orginal, because the numbers don't match.  What is there is a CB750E-2509584 engine.  I checked the Honda Chopper site and it listed it as a F0 engine.  I'm a little confused I thought SS engines had an F indetifier not E, but the number shows F0.
So do I have an F0 engine or a K engine?
Any insight would be awesome, thanks guys.
Travis
Forum member #9962
1992 GL1500 Interstate
Re: F engine indentification
« Reply #1 on: December 07, 2010, 06:51:14 PM »
 Does it have studs, is it black? look on top fin of nead  at rear between 3 &2 carbs for a number..
Offline Old Scrambler
« Reply #2 on: December 07, 2010, 06:58:00 PM »
Yes, its an early F motor that is most similar to a K.  The pistons have a slight dome like the K7-K8. Minor gear changes in 4th and 5th, and maybe a slightly improved cam grind.  More reliable valve-train than the later black motors.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline Trav-i
« Reply #3 on: December 07, 2010, 07:02:08 PM »
Thanks Scrambler,
I thought that was the case I just wanted someone who knows more then me to confirm it for me.  I am actually happy it's not the more troublesome F engines.
BTW good to talk to you again, we met at Barber this year in the VJMC area.
Forum member #9962
Hinomaru
« Reply #4 on: December 08, 2010, 08:02:03 AM »
Here's a very good reference for serial numbers and comes from the Honda published Motorcycle Identification Guide:
CB750 F models:  http://www.spookytoms.com/CB750F-IDPlates.html
CB750 K models:  http://www.spookytoms.com/CB750K-IDPlates.html
