Author Topic: Update: Holy Bodgejob Batman!  (Read 6896 times)
Offline tango911
Re: Holy Bodgejob Batman!
« Reply #25 on: November 06, 2010, 05:10:09 PM »
i told you if you posted that pic people would get a kick out of it!! :P
CURRENT STABLE:
1969 Honda Dream 305 (black)
1974 Mach III kawi 500 smoker
K2 (project)
K2 Original fixer up
K0 original fixer up
2006 CRF250R
Offline Nortstudio
  • Not nearly an
  • Just getting started...
    • MotoPreserve
« Reply #26 on: November 06, 2010, 05:20:15 PM »
It's pity :)
1976 CB550K...in progress
1975 CL360...eventually custom
2009 Husqvarna TE610
a blog about wrenching in Brooklyn, NY
“Success is dependent on effort.”
~Sophocles
Offline Frankencake
  • Yesssssss,
  • "I like the old junk"
« Reply #27 on: November 06, 2010, 05:27:14 PM »
I was trying to get my oil pressure light to work, and finding that the wire end inside the bucket was attached, I took off the cover on the left side to see if it had come apart at the oil pressure switch.  The picture below is what I found...  Seems like some sort of "something" that was once in paste form, and hardens like nails!  Any idea if I try to take this thing off to replace it, will it snap something important in there?  The parts fiche shows the part, but not exactly what can of worms I will be opening :)
Is this a 550?  If so, I have what you need for the low, low price of shipping only.  I'll pull it off this week if you need it.  My donor engine is a '77 that I'm slowly taking apart.  Let me know, and you won't have to worry about that JB Weld crap.
333:  Think "Shakeweight".
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #28 on: November 06, 2010, 05:37:09 PM »
It is!  I would appreciate it more than you know.
~Sophocles
Offline Frankencake
  • Yesssssss,
« Reply #29 on: November 06, 2010, 05:49:14 PM »
Finally!  Someone who needs parts for a 550 engine!.  I've been holding on to this thing for a few years now and offering it up once in a while.  I got your PM.
« Reply #30 on: November 06, 2010, 05:52:21 PM »
Mighty nice of you Cuppy!
Offline Frankencake
  • Yesssssss,
« Reply #31 on: November 06, 2010, 05:54:03 PM »
What goes around, comes around.
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #32 on: November 06, 2010, 05:57:01 PM »
I'm going to start thinking of how I can hold up my end of the "comes around" bargain.
Thanks again!
~Sophocles
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #33 on: November 06, 2010, 08:46:33 PM »
Till then check the regulator and rectifier. Considering the skills of the PO, I wouldn't be suprised if they were toast.
What would I be checking for without the regulator and rectifier?  How would I know they are malfunctioning? I have found the regulator in the shop manual, but I don't even know where the rectifier is...
Thanks
~Sophocles
Offline DavePhipps
    • Hillside Technology
« Reply #34 on: November 06, 2010, 09:00:48 PM »
Will look for pics and testing info and post them tomorrow. It's midnight here and I'm off to dreamland. OK, off to dreamland after I tell my kids to get off the Xbox, and other laptop.
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
Offline bender01
« Reply #35 on: November 06, 2010, 09:18:39 PM »
For extra referance (sp) My 75 550k's dead unit before I replaced it.
75 550 K1
74 750 K4
1968 450 K1 Super Sport
74 750k 836 project
Good luck!
Two Tired Quote !
Offline Frankencake
  • Yesssssss,
« Reply #36 on: November 06, 2010, 09:38:03 PM »
Thanks again!
You wouldn't happen to have a set of good shocks for a 750, would you?
Of course, it's not a deal breaker if you don't.
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #37 on: November 06, 2010, 11:13:47 PM »
Unfortunately no.  I've just got this broken down beast (my first) and it's in need of shocks too.
~Sophocles
Offline gnarlycharlie4u
  • Far from being an
« Reply #38 on: November 06, 2010, 11:16:16 PM »
« Reply #39 on: November 06, 2010, 11:31:52 PM »
the switch is an on/off type,its on with no pressure,turn the key on and the lamp should light,no oil pressure,you start the engine and oil pressure opens the contacts and your tell tale lamp goes out,to test it,remove it from the pump,then with a globe or meter,the main body will have full continuity to the terminal connection,the globe should light if not the switch is buggered,if you can blow air into the sensor hole in the thread at the same time the globe should go out,these are set a a specified pressure for different cars or bikes,its not real important to get the right one,you dont want a tight one that flickers at idle though,even though your oil pressure is ok at idle the sender is set at higher pressure for some other model car or bike and speaks with false tonque.
Offline 05c50
  • 05c50
    • Classic Motorcycle Solution
« Reply #40 on: November 07, 2010, 04:39:11 AM »
Wear a helmet,the life you save may be your own.Ask me how I know.               CB650C,CB550F,GL1000,CB750A
Offline DavePhipps
« Reply #41 on: November 07, 2010, 05:46:07 AM »
Are you're stock shocks toast?
I'm attaching the rectifier test info. The rectifier is located under the left sidepanel.
Have you downloaded the 500/550 factory service manual? This is from page 97.
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #42 on: November 07, 2010, 06:07:52 AM »
Sorry, should have updated you. I just read this exact section last night. What I'm not finding is the regulator. When the post felt that they might be toast, I realized I know nothing about them.
What would be the telltale signs of disaster?  Battery not charging?
Thanks for all the info.
Scott
~Sophocles
« Reply #43 on: November 07, 2010, 06:35:01 AM »
Yes, battery not charging.
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #44 on: November 07, 2010, 06:45:37 AM »
Well... thanks folks.  This goes on the list to check.
I have been having some decent luck with the battery, it stays charged pretty well, but sometimes it's easier to kick start after a couple days sitting idle, and then the electric starter works fine for the rest of the day.  I have been bringing the battery up to my apartment occasionally to tender/recharge the battery.  That usually does the trick.  Works great as long as I'm starting it daily (or even every other day).
I assumed the cold weather was making it tough on those days after sitting (been in the 30's here at night).
~Sophocles
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #45 on: November 07, 2010, 07:00:57 AM »
Dave,
Don't have any frame of reference for the shocks (or any of this bike really), but they certainly look worn and rusted.  And although I have read several posts about the lack of comfort with the stock shocks on these bikes, it's always somewhat alarming when I hit a pothole or deep manhole cover here in the city.  Pretty rough, stiff "bottoming out" feeling.
~Sophocles
Offline Frankencake
  • Yesssssss,
« Reply #46 on: November 07, 2010, 07:09:30 AM »
Dave,
try giving your shocks springs a bit more preload compression by turning the collar on the shock.  Doing this might help with that bottoming out feeling.  It also depends on how big of a guy you are.
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #47 on: November 07, 2010, 07:18:38 AM »
Does this adjustment need to be done with the special wrench that came with the tool pack?  That tool, along with the rest of them, is long gone...
I'm about 200lbs.  But these bumps can be monsters!
~Sophocles
« Reply #48 on: November 07, 2010, 07:23:56 AM »
See link for the tool, but you may not necessarily need it.
If your shocks are adjustable, they just need to be rotated.
http://cgi.ebay.com/ebaymotors/SHOCK-SPRING-ADJUSTING-TOOL-ATV-DIRT-BIKE-MOTORCYCLE-/400165144419?pt=Motors_ATV_Parts_Accessories&hash=item5d2bb38763
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #49 on: November 07, 2010, 07:36:49 AM »
That's the one.  I definitely see what the manual is talking about with the I-V adjustments, I just wasn't sure how to rotate them.  can I do it by simply removing the weight from the shocks and turning them?  The manual shows a dude holding the special spanner, but gives no description of what exactly he is going to do with it??? :)
I also see that there are nipples for grease, but I have yet to get a grease gun, so that would probably be a good step too.
~Sophocles
