Author Topic: K carbs on F2  (Read 589 times)
Offline stever
  • Cafe almost back! I've got a
K carbs on F2
« on: November 07, 2010, 10:57:33 AM »
I have a beautiful rack of cleaned,adjusted, and polished 77 K carbs from an old project that I would like to use on a 77 F2 engine. I notice they are different part numbers from Honda. What are the differences and can I run them on an F2 engine without problems? I would like to use the F boots too, but I have K boots if needed. Thanks, Steve.
If you don't have anything good to say about something..... come sit next to me
Online HondaMan
Re: K carbs on F2
« Reply #1 on: November 07, 2010, 05:30:35 PM »
They should run fine. So long as the hoses (both ends) match up, almost all of the 750 carbs will interchange. The airbox hoses: check yours to make sure the flange side fits the carbs you will use in the end. The early (K1-K6) airboxes had smaller hoses, won't fit the later ones.
Offline SOHC Digger
  • I'm not an
Re: K carbs on F2
« Reply #2 on: November 07, 2010, 06:00:58 PM »
They'll run.  Tune them to your engine and you'll be alright.
