Author Topic: Air Filter & Stack Filter Kit for 550's & 750's / The end, see post #898, pg 36  (Read 203388 times)
Offline y2kc0wb0y
  • B00msh0cka
  • Shoot the pickle....
Re: Air Filter & Stacks Combination for 550's & 750's
« Reply #525 on: May 05, 2011, 07:30:17 PM »
Looks great. Really hoping for some tuning success with this set up.
CB750K3 890cc| 2004 VFR800A| 76 CB550F| 77 CB750F| 73 CB350G| 79 XLH| 2007 BMW R1200GS| CB750K2
Offline Tintop
« Reply #526 on: May 05, 2011, 07:39:44 PM »
thanks, yours is the box in the bottom right of the last pic. ;)
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
« Reply #527 on: May 05, 2011, 09:28:55 PM »
Excellent stuff Tintop.....    We all very much appreciate the time and effort you have put into this little endeavour   ;)
Offline Syscrush
  • Sold. :(
« Reply #528 on: May 06, 2011, 05:56:52 AM »
That stuff is sexy.  I should probably get a set and just make my frame/exhaust/suspension work with it, eh?
« Reply #529 on: May 06, 2011, 07:55:26 AM »
You won't be disappointed mate, my K1 (fitted with Brians "Ram Charger" filter setup) has never run better! ;D
Offline Tintop
« Reply #530 on: May 06, 2011, 03:30:00 PM »
Those nice red 550 stacks would be an interesting start.  I'm using the yellow ones on my K3, and that's about the sum total of were I'm at with the colour scheme.  LOL
77 CB550 Cafe build
Offline Kong
« Reply #531 on: May 07, 2011, 03:07:46 PM »
Now I'm getting excited.
2002 FXSTD/I  Softail Deuce
2001 Acura (Honda) CL Type-S
1986 Honda Rebel, 450
1978 Honda CB550K
1977 Honda CB550K
Offline kmb69
« Reply #532 on: May 07, 2011, 04:48:49 PM »
Terry's comment has pushed me over the TinTop!
Do you still have a set for the K0-K1? Is the price in your first post still good?
Thanks, Keith
« Last Edit: May 07, 2011, 04:57:32 PM by kmb69 »
Offline Tintop
« Reply #533 on: May 07, 2011, 06:49:56 PM »
Thanks, Keith
PM sent Keith.
77 CB550 Cafe build
Offline Tintop
« Reply #534 on: May 10, 2011, 07:19:28 PM »
1st orders (550 & early 750) go to the Post Office tomorrow. ;D ;D
The 750 PD orders should be shipping early next week.  Everything is boxed with a shipping label, just waiting for the stacks to arrive.
77 CB550 Cafe build
Offline decafe
« Reply #535 on: May 11, 2011, 04:16:42 AM »
First post on this forum, I just got my first Honda, a 1978 cb550k, the guy I bought it from was a legend, he did some very nice work on it and kept it mint. I am also new to tunning carbs, and really feel like my bike could us it. It currently has pods, aftermarket 4into1 and has supposedly been tuned with 105 jets and the floats set to 13mm.
Now my questions to all the gurus: The bikes idle RPM's are very hard to control before it is rode for at least 30min, the RPM's are all over the place from 1400 to 4000 with just the slightest twist of the throttle then I have to readjust the throttle at the carb. after readjusting about 6 times and ridding for about 30min it's fine.
It sounds like in this thread this could be due to the carbs being hard to tune with pods, should i ditch the pods and go for one of these puppies?
I am going to attempt to sync the carbs this weekend, hoping this helps a bit.
Thanks heaps!
Also previous owner said he thought the carbs could use a slightly larger main main jet like a 110.
Offline Flying J
« Reply #536 on: May 11, 2011, 10:15:22 AM »
Welcome to the forum. Yes pods cause problems. Yes it seems that this filter can alleviate these problems. Should you drop $$$$ to get one? Sure if you have it to spend. You should start a build thread on your bike where you can ask questions about tunning and jet your carbs as well. Also you could tell us about this "legend".
Offline Tintop
« Reply #537 on: May 11, 2011, 03:23:53 PM »
Welcome to the forum decafe.
Your 78 550 would have come with 46C PD carbs, is that what is still on it?  That would be my 1st question, as these were jetted lean from the factory.  Regarding your the issue with the idle.  My 550's 46A PD's currently have one size larger slow jets (40's), and 98 mains (stock 76 sizes), and is very lean above 4K.  However, it starts (on choke), idles very nicely, and pulls cleanly.  I will be going to 110's, possibly 115's because of my pipes & the filter.  So your 105's could be slightly lean at the top end.  The fact that the idle problem seems to go away once fully warmed up is interesting.  Have you checked that the carbs are closing freely (no cables), and that the cables are in good condition, routed properly, and move smoothly?.  Quick, simple test - (cold, without engine running) roll throttle open to 1/2, 3/4 open, then let go of throttle.  The carbs should close instantly, with an audible snap.
For a carb sync to be any good, all the other parameters have to be in spec. 1st (timing / valve clearance - the basic 3K tuneup).
As ffj said, the filter kit was designed to alleviate the slow speed / part throttle problems Pods cause by the removal of the stock stacks, while promoting free breathing everywhere else.  I do have 550 kits available (blk, or red stacks currently), but will leave it to you to decide if it is for you.
77 CB550 Cafe build
Offline Tintop
« Reply #538 on: May 11, 2011, 04:17:21 PM »
The 1st packages have gone. ;D ;D ;D  You should expect them in 6 / 10 days, so likely before next weekend. ;)
There are two things I forgot to do though.  One was to include the install notes, which I will email to you.  The 2ND was to remove the flash at the bell.  In my haste to get things packed, I simply forgot.  My sincere apologies for this quality control oversight.   A quick wipe with some fine paper will remove it. ::)
Looking forward to the 1st feed back.   Thankyou to all who have stepped up, and supported this project.
tintop / Brian
77 CB550 Cafe build
« Reply #539 on: May 11, 2011, 07:57:41 PM »
Ha ha, "Legend" is just gushing Aussie slang for someone who you think is really cool mate, not necessarily a real "living legend" like Neil Armstrong, or Barak Obama......... ;D
Offline decafe
« Reply #540 on: May 12, 2011, 06:32:56 AM »
Wow, thanks guys for all the quick feedback I really appreciated it, I didn't expect anyone to care.
Thank you Tintop, I will look into the carbs closing and cable, timing and valve clearance this weekend, I suspect these should be 'spec' as the 'legend' was pretty pedantic about this bike, who knows until I investigate though. I will probably end up purchasing one of your filters but I want to learn how to get the bike tuned as best possible as is before I start spending more money unless these bikes are near impossible to getting running well with pods - thoughts?
ffjmoore thanks for the suggestions, I'll start a build thread for the bike...hopefully people will look at it.
Now the 'Legend', yes Aussie slang but the guy is awesome, named Fast Eddy supposedly used to frequent this forum.
Thanks all!
« Reply #541 on: May 12, 2011, 04:26:28 PM »
If you manage to get some semblance of tune from pods you are going to have to retune if you buy Tintops filter. I would throw the pods at someone you don't like and go with Tintops filter, tune once and forget..... ;D ;)
Offline y2kc0wb0y
  • B00msh0cka
« Reply #542 on: May 12, 2011, 04:49:36 PM »
@ RR. I sure hope so. This 836cc bike is terrible below 4K and fowls plugs badly under normal driving and is lean lean lean @ WOT. 120 mains/40 idle with mid cam. Shouldn't be this way and I've gone up and down jet wise trying to fix it.
« Last Edit: May 13, 2011, 09:55:31 AM by y2kc0wb0y »
« Reply #543 on: May 12, 2011, 04:52:31 PM »
What air filters are you running.? Terry has Tintops filter on his 836 and loves it....
Offline y2kc0wb0y
  • B00msh0cka
« Reply #544 on: May 12, 2011, 06:42:33 PM »
Pods...I was really thinking of going back to the airbox when this option came along so time will tell.
Offline Tintop
« Reply #545 on: May 12, 2011, 07:24:08 PM »
Your's is on it's way y2kcowboy.  Postal (& border security ::)) willing it should be there for next weekend.
One thing to check given your symptoms is the needles.  If they are the originals (K3?), they may be worn in the part throttle area, were most daily riding happens.  This would cause the rich going lean issue, as the rest of the needle would be original dimension.  Changing jets to cure one end, would make the other worse.  Where do you have the clip set at?
77 CB550 Cafe build
« Reply #546 on: May 12, 2011, 07:43:31 PM »
I sure do Mick, no change to my stock carbs except 130 mains, and it goes like a rocket! (well, it did before I blew the head gasket, but considering the punishment I've dished out on this engine over the last 5 years, I'm surprised that I haven't blown it up!) ;D
Offline y2kc0wb0y
  • B00msh0cka
« Reply #547 on: May 13, 2011, 09:57:18 AM »
I suspect it's set too high? but I don't know exactly.
Offline SF
  • I burn gas very well
« Reply #548 on: May 13, 2011, 11:05:30 AM »
JUST GOT MY ANTI-POD ;D VERY WELL PACKED AND READY TO GO! JUST WISH I WAS AT THAT STAGE IN MY BUILD :o
THANKS TT LOOKS GREAT.
SHAWN
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
rgid springer bobber project
Offline Tintop
« Reply #549 on: May 13, 2011, 05:06:49 PM »
ha ha - forgot one only had to go up the road 45 minutes.  Glad it arrived OK SF, I was planning on emailing out the install sheet tommorrow.  I'll make yours the 1st to go.
We'll have to plan a ride this summer.
77 CB550 Cafe build
