Author Topic: Air Filter & Stack Filter Kit for 550's & 750's / The end, see post #898, pg 36  (Read 256854 times)
Offline Flying J
Re: Air Filter & Stack Filter Kit for 550's & 750's / The end, see post #900
« Reply #900 on: April 25, 2013, 10:58:49 PM »
Thanks brian, Glad i got one. I just put it on yesterday. Looks great.
Offline SOHC Digger
  • I'm not an
« Reply #901 on: August 21, 2013, 08:43:34 AM »
I'm gonna bump this thread every so often to see if there's a newcomer who might be able to pick up the torch and run.
I love my setup.  It looks race-ready and performs well.  I am thankful to have gotten one when I did but I know there are others who are sad they missed out.
Offline SF
  • I burn gas very well
« Reply #902 on: August 21, 2013, 09:14:46 AM »
glad i got one when i did and glad i met TT in trenton when he was building his 550
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
rgid springer bobber project
Offline pjwalsh
« Reply #903 on: August 31, 2013, 05:59:42 AM »
Thanks to Terry, and his greatly appreciated help I am now closer to running the anti pod.
Im in Sydney Australia, before mods I was running a standard 4 into 4 exhaust, air box, 125 main/40 slow jets and needle clip set at second position from the bottom. This ran like a bucket of #$%*!
The only other mod I performed was to raise the needle to its last position and retest the set up and WOW.
only a minor hesitation low in the rpm but opens it up in the 4000-5500 rpm range.
more testing tomorrow, thanks to all you guys here for the insight and knowledge!
Offline neilc
  • old school biker,other bike is a 2003 vtx1800c
« Reply #904 on: August 31, 2013, 08:50:07 AM »
I need length and width dimension,i have a custom frame
Offline SOHC Digger
  • I'm not an
« Reply #905 on: August 31, 2013, 10:34:07 PM »
Are you looking to buy one, or produce them?
Offline Tintop
Re: Air Filter & Stack Filter Kit for 550's & 750's / The end, see post #899
« Reply #906 on: September 06, 2013, 07:23:57 PM »
I have spoken with ITG and they will continue to supply the filters as bespoke units.  See post #899 for further information.
tintop
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline dlhoulton
« Reply #907 on: September 09, 2013, 09:30:22 AM »
For anyone interested in getting one of these filter setups, as Tintop has reported ITG will still sell one. You have to contact there U.S. distributor: http://www.itgairfilters.com/distributors2.asp?section=distributors&ID=32 , and talk to Gary Donahoe. Gary stated that if you call him at: 714-842-2603 he will place an order for the filter. Gary stated that for the 77/78 CB750 filter it will cost $238.90 plus shipping. This will be for a domed filter and blank base plate. You will still have to contact Paul Gabor from: http://www.classicmotorcyclesolution.com/ , to get the custom stacks. They will run you another $35 plus shipping.
dlhoulton
Offline spdygnzlz
« Reply #908 on: September 09, 2013, 09:40:06 AM »
Aweseome!  Thanks for looking into it.  I'll be ordering one ASAP since I missed the boat when Tintop was getting these done.
Offline dlhoulton
« Reply #909 on: September 09, 2013, 09:55:59 AM »
I did mention that this will have BLANK base plates. You will have to figure out hole spacing and size. As for the custom stacks that price was for black. Will be more for color. Also the stacks do not come with the band clamps.
dlhoulton
Offline Tintop
« Reply #910 on: September 09, 2013, 12:41:55 PM »
I have update Post #899 to include the contact info for Canada & the USA, along with drilling info for the 500/550, early 750 carbs, and later 750 PD's.
If anyone still has questions they can contact me @ brian.robinson7@sympatico.ca.
77 CB550 Cafe build
Offline KrautKoffin
« Reply #911 on: September 09, 2013, 01:15:44 PM »
Anyone thought about just selling drilled back plates? I'd love one of these kits, just dont have the tools available to drill them at the moment.
74 cb550
I now have Beastie Boys "Sabotage" stuck in my head after seeing your avatar.
Offline spdygnzlz
« Reply #912 on: September 09, 2013, 06:58:04 PM »
Tintop, do you have the cad file or drawing available for the back plate?  I have a buddy who is always up for CNC'ing parts so if we have enough interest, I could ask him to cut a few.
Offline IRISHCBRACER
    • My first build - 1976 CB550
« Reply #913 on: September 30, 2013, 08:51:02 PM »
I made an offset plate for my 550 to pull the filter off the frame by 10mm. The ITG filter is so nice looking!
Offline KrautKoffin
« Reply #914 on: October 09, 2013, 01:58:46 PM »
Looks awesome! Anyone want to pick up the torch and run with this yet?
74 cb550
Offline Syscrush
  • Sold. :(
« Reply #915 on: October 10, 2013, 06:51:00 AM »
It does look very good, nice work.
Have you had it running yet, though?  The original setup was designed with some specific flow parameters in mind.  With the stack mouth opening 10mm closer to the foam element now, you may end up with tuning issues.  Hopefully not!
« Reply #916 on: October 10, 2013, 09:58:03 PM »
I am still in the middle of building the motor. The inside of the filter has mesh wire support so I don't think 10mm will cause any deflection etc. I will know next spring when I am putting the motor back in :)
« Last Edit: October 10, 2013, 10:01:07 PM by IRISHCBRACER »
Offline Syscrush
  • Sold. :(
« Reply #917 on: October 11, 2013, 09:15:11 AM »
My concern is not deflection, my concern is turbulent flow into the carb causing tuning issues.  I could be wrong and I'm not keen on re-reading 40 pages of this thread, but I thought that the filter 's inner volume was sized in such a way that it would help ensure uninterrupted laminar flow into the carb.
I know that the design of the stacks with the half-round edges was due to that, I thought that  the clearance between the stack mouth and the inside of the filter element was another important factor.
I think that what you've done looks great, and with the 550's smaller carb dia hopefully the flow will work well, too.  If it does work well I wouldn't be surprised to see others doing a similar mod.
« Reply #918 on: October 11, 2013, 09:40:59 AM »
No disrespect to Tintop at all, but I am just wondering was the original design done with a simple flat sheet metal plate for simplicity and cost effectiveness. My design obviously is a little more complex to manufacture and would cost more than a flat plate with holes. We will find out how it work this Spring all being well.
Offline KrautKoffin
« Reply #919 on: October 11, 2013, 10:23:49 AM »
I called my local ITG rep (for all of California) and he said that part number didn't work. Anyone have the ITG part number for the 750s?
74 cb550
Offline spdygnzlz
« Reply #920 on: October 11, 2013, 10:59:52 AM »
I Just ordered the velocity stacks from Paul @ http://classicmotorcyclesolutions.com.  Also have an email out to Andy at ITG regarding the filter.  Hopefully, I'll hear back from him soon and I'll post info here.
Offline KrautKoffin
« Reply #921 on: October 11, 2013, 12:18:40 PM »
Thanks, I'm just waiting for Paul to send me an invoice! Let me know about the filters when you hear back. What bike are you building these for?
74 cb550
Offline spdygnzlz
« Reply #922 on: October 11, 2013, 02:00:22 PM »
I'm in the middle of building my 550/650 hybrid.  Carbs are early cb750 models.  I have the usual K&N pods on the filters now and they fit fine so hoping this setup will also not have a conflict...  Good thing the pods are still in their plastic.
Offline Tintop
« Reply #923 on: October 11, 2013, 08:07:08 PM »
KrautKoffin - the P/N's in post #900 is the ones ITG assigned to the two filters.  These not a standard ITG # listing.  Have your ITG rep contact Andy @ ITG.
IRISHCBRACER - All this style of filter from ITG uses a flat back plate, regardless of application.  Syscrush is correct re sizing, and flow.  The rule is the minimum distance from the bell mouth to the inner surface of the filter should not be less than the ID of the carb throat.  The sizing for the 500/550 is just over that, same with the 750.  In actual fact the stacks for the 500/550 that Paul made for me are slightly shorter than stock to make everything fit within those parameters, and the frame rails.
77 CB550 Cafe build
Offline KrautKoffin
« Reply #924 on: October 11, 2013, 10:54:50 PM »
Thanks Tintop, I'll get it figured out. As for the drilling of the holes for the 750, got any illustrations?
74 cb550
