I doubt the "tester" is using stock carbs on the various "test vehicles". How are you planning to manage fitting 750 stacks on these various machines carb sets?
Good work fellas....test away.
Thanks bwaller, sure you don't want to try 750 carbs on that race motor of yours? You could always bore them.
Terry has had the stock carbs on all his bikes, including the 836.
Just one small correction Brian, as Brent knows that I'm running 32mm CV's on my gold 836cc K2, but I took the CR's off my K1 fitted with the hot 836 and am back to running stockers. (I hated the CR's, I've got some modded 33mm Mikuni smoothbores for my 1060cc RC engine and I've used them before on a Suzuki 1100 Drag bike and they were great)
I've got a K6 top end on my F2, so I'll be able to compare Brian's filter set up on both extremes, a stock as a rock CB750, (albeit with electronic ignition and 4 into 1 pipe) and on a worked 836 with 12:1 pistons, JMR stage 3 head, Megacycle 125/75 cam, etc etc. I'm going on a months leave in a couple of weeks, so I'm looking forward to putting in a lot of riding! Cheers, Terry.
