OK. I did some work this weekend and eliminated some possibilities....Still stutters.
I checked the advance unit and it's performing just fine. I cleaned and lubed it just in case. I also set timing with a light, so it's spot on.
I didn't buy a compressor because I'm waiting for Black Friday sales. However, I bought berryman's in a can and sprayed through the pilot circuit liberally. I then re-synched my carbs. I did notice that what is synced at idle isn't synched at 3,000 RPM. I got things as close as I could without pissing off all the neighbors.
I rode to work today, even though it was 38 degrees outside, and had the same issues. I've got nice color on plugs 1,2 & 3, but 4 is all fouled up. I'm going to try backing the idle screw out to 2 turns out on my drive home. I've tried switching jets around to different carbs, but it's always #4 that is rich.
My question to other people with this problem: Do you also have just one cylinder that runs rich?? It would help to know if I'm on the right track.
Thanks
