Author Topic: only running on cyl 2-3  (Read 1121 times)
Offline 000jeremy
« on: November 12, 2010, 07:42:27 PM »
77 cb550f
Ive already replaced all plugs and gone through the carbs.  I know that only cylinders 1-4 are firing, but I dont know where to start going through the igintion or what/how to check?  I have a dyna-s btw
THanks in advance,
Jeremy
Re: only running on cyl 2-3
« Reply #1 on: November 12, 2010, 07:55:42 PM »
touch pipes 1/4 are they cold?pull all the plugs then see if 1/4 have any spark?if no spark try putting your thumb on the plug wire and see if it has a feeble kick,do all this with the tank off,check the wires are not disconnected or dirty connections for the coils,are they dyna coils?did a po fit the dyna?google the install instructions and check the basic settings for it.
