Author Topic: compression  (Read 1584 times)
cyclezirk
compression
« on: March 14, 2006, 09:48:35 PM »
I have read all the posts (threads).  Please correct me if I am wrong...but is this how to do a compression test:
1. Warm engine
2. Choke off
3. Throttle wide
4. Plugs out
5. Screw in tester and push the starter
6. Read the guage
7. Move to the next one
 :P
Offline Robert
  • Sorry for my English
Re: compression
« Reply #1 on: March 15, 2006, 02:09:56 AM »
That's the way I do it.
You push the starter until the needle of the gauge is not moving any further.
Obviously you want to have a good charged batterie for the test, to have enough juice for the four testing sessions  :)
On thing to add though: Kill switch is switched to OFF while testing :)
« Last Edit: March 15, 2006, 02:17:56 AM by Robert »
cyclezirk
Re: compression
« Reply #2 on: March 15, 2006, 12:28:25 PM »
Thank you.  I appreciate your help. :)
Offline Tim2005
Re: compression
« Reply #3 on: March 15, 2006, 02:42:22 PM »
One more thing... turn the fuel tap off too, saves flooding the motor.
Offline Bob Wessner
  • "Carbs Suck!"
Re: compression
« Reply #4 on: March 15, 2006, 03:23:56 PM »
I'd even drain the carb bowls, no need to suck any fuel in that won't get burned-off.
