Author Topic: Chain lube...and the use thereof  (Read 1337 times)
Offline techy5025
  • 1969 Diecast and Sandcast 750's
« on: March 15, 2006, 12:25:07 AM »
The question is/are...
1.  What kind of chain lube do you guys use?
2.  How often do you use it?
3.  Do you use it sparingly in one spot and let the rotation lube the whole chain or
     douse the whole chain, or remove the chain and soak it, or ???
I have been using a foam type and spraying the whole chain on the bike as I hand
rotate it, but this results in some drippage (is that a word   ;D )  I'm trying to keep
from soaking the whole back of the bike and the pipes.
Jim
1969 750 K0 (Reborn)
1969 Sandcast 750 K0 (Reborn)
2003 CBR600F4I
Offline mrbreeze
  • Not your average
Re: Chain lube...and the use thereof
« Reply #1 on: March 15, 2006, 12:31:27 AM »
There are alot of posts on this subject and many different ways to go about it.I would say the important thing is to do it frequently and keep the slack in check. If you neglect chain maintenence,you risk alot more than just the cost of a new chain.
MEMBER # 257
chopper_harris
« Reply #2 on: March 15, 2006, 02:21:13 AM »
Wurth High Perf Dry Chain Lube - goes on like a wax, doesn't fling off.
Recommended by Ride Magazine test, works for me  ;)
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #3 on: March 15, 2006, 02:32:09 AM »
Most of the spray can lubes go on with a thin vehicle which evaporates leaving behind the heavier lube. Just make sure you get it between the side plates on both sides and into the roller ends. When I finish, and it's had a chance to set-up, I wipe he excess off the outside with a rag. Too much lube on the outside merely collects dirt and sand and contributes nothing to the lubing of the chain. Inevitably it will collect dirt/sand anyway. Periodically you should give it a cleaning. I use kerosene and one of those three sided brushes you can pick-up at any motorcycle shop, then dry it with rags and re-lube. Check the polls area to see how frequently folks lube theirs. Once per year, say at the end of the season (unless you are lucky enough to live someplace where you can ride year-round) it's a good idea to remove the front sprocket cover and inspect/clean the area around the sprocket. It can collect a surprising amount of sand and dirt and build-up over time.
Offline Gordon
  • 750K1, 550K2
« Reply #4 on: March 15, 2006, 06:00:11 AM »
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #5 on: March 15, 2006, 09:07:36 AM »
I posted about Wurth products a while back. I went to my local Yamaha dealer to get some Yamaha Carb Cleaner which everyone reckons is the best: "Nah mate - we use Wurth cleaner here" !  I emailed Wurth from their website about which of their products to use - no reply.
Chelsea fan Mr Harris?
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
Offline techy5025
« Reply #6 on: March 15, 2006, 11:57:49 AM »
Thanks for the link Gordon...how did I miss that post. ::)
Some great Ideas.
Jim
2003 CBR600F4I
Offline Uncle Ernie
« Reply #7 on: March 15, 2006, 06:23:57 PM »
I've been using PJ1, but we recently got some synthetic stuff that looks interesting.  I lay newspaper under the chain, and hold another piece behind where I'm applying it.  I use it every couple hundred miles.
Offline techy5025
« Reply #8 on: March 15, 2006, 06:44:47 PM »
I took the bike completely apart to the frame and reassembled it.  Its
funny but as I am riding it I always have this tiny fear that a wheel is
going to fall off or something because I didn't torque it right. :o
I have the same thoughts about the chain breaking....hence the lube
question.
Jim
2003 CBR600F4I
