Author Topic: CB650 Carb Question  (Read 728 times)
Offline Calflash
CB650 Carb Question
« on: November 20, 2010, 06:11:48 AM »
The carbs have been sitting for 5 years. All the "O" rings and bowl gaskets leak.  Will the "rubber" swell back up with gas in the carbs? If the answer is no, where can i get the "O" rings and carb ,air cut offs and accel pump kits?
Calflash
US Army
Nam 66-67
80 CB650
Offline cb650
Re: CB650 Carb Question
« Reply #1 on: November 20, 2010, 06:30:44 AM »
Dont know where exactly just be sure to get the right kit.  79/80 had Mech and 81/82 had CV's and parts dont interchange.  If the orings are still in one piece you can use a little hylomar sealant.
Offline Calflash
« Reply #2 on: November 20, 2010, 07:17:02 AM »
Cycle-re-cycle has carb kits. Any opinions on the quality of their kits?
Calflash
US Army
Nam 66-67
80 CB650
Offline cb650
« Reply #3 on: November 20, 2010, 09:34:09 AM »
I never have bought a kit.  Always had enough parts laying around.   Kit has and should have them posted in one of her threads.
Offline Hush
« Reply #4 on: November 20, 2010, 10:25:33 AM »
Rubber "O" rings will be dry as after 5 years so if they are not perished they could be reused with a tube of gasket maker, use the "never set hard" type. :)
I would be replacing the tiny accelerator "O" ring just cos it's a #$%* to relocate and it will be poked, also check the condition of the plunger mechanism on the bottom of the accelerator rod as one set I bought from the wreckers was so dry it crumbled when I removed it.
« Last Edit: November 20, 2010, 09:43:05 PM by Hush »
Offline cb650
« Reply #5 on: November 20, 2010, 02:21:49 PM »
The hylomaris made for gas and never dries.  I used it on a set of carbs 12 years ago and last year I had them apart it was still gooy.
Offline Calflash
« Reply #6 on: November 20, 2010, 03:18:56 PM »
what is hylomar and where do you get it?
Calflash
US Army
Nam 66-67
80 CB650
Offline cb650
« Reply #7 on: November 20, 2010, 04:56:17 PM »
I got mine at checkers now orielys.   Many years ago
