Author Topic: fork extensions  (Read 8492 times)
dcil
fork extensions
« on: November 24, 2010, 06:18:16 PM »
Anybody know where I can find fork extensions for the 35mm cb forks?
dcil
Re: fork extensions
« Reply #1 on: November 24, 2010, 06:33:59 PM »
I read somewhere that the cb750f forks are longer than the cb550f. Anybody verify this? If so, know how much longer?
Re: fork extensions
« Reply #2 on: November 24, 2010, 07:53:14 PM »
 To start with what year/model bike.. ??? And where in the world.. ???
  Slugs as they are called were considered dangerous and became unpopular, partially due to the lengths they were running. That was over 30 years ago..
 What length are you looking for? Get new extended, or cut down longer ones.  Often on here people are looking to trade good stockers for extended ones..
Offline SOHC Digger
  • I'm not an
Re: fork extensions
« Reply #3 on: November 24, 2010, 07:56:08 PM »
CycleX sells extended forks.
dcil
Re: fork extensions
« Reply #4 on: November 25, 2010, 05:37:00 AM »
Sorry. 1975 cb550f And I'm in Georgia,USA. Only looking to gain an inch or two.
Offline SOHC Digger
  • I'm not an
Re: fork extensions
« Reply #5 on: November 25, 2010, 12:51:02 PM »
[/quote]
Man, how many times have I said that...
Re: fork extensions
« Reply #6 on: November 25, 2010, 05:02:40 PM »
The slugs that I'd seen back in the day were essentially pieces of fork tube with a male end like the cap nut, which screwed into the top of the fork tube, and a female end then to receive the displaced cap nut. As long as the seam was between the 2 clamps, one might think them safe. Scared me from the get go. And either they were too expensive or to liable, I don't know, they never caught on and besides a few pair i saw 35+ years ago, have never seen or heard of them again.. Could be made by a machine shop I suppose.
Offline Calflash
Re: fork extensions
« Reply #7 on: November 26, 2010, 04:35:32 AM »
Look up "Forks by Frank". They make good extended forks about $100 a set.
Calflash
US Army
Nam 66-67
80 CB650
Offline Tintop
Re: fork extensions
« Reply #8 on: November 26, 2010, 05:07:59 AM »
+1 on contacting Frank.  His tubes are better than orignial, and he will supply whatever length you require.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Re: fork extensions
« Reply #9 on: November 26, 2010, 06:09:46 AM »
Yes, AKA Frank's Maintenance" http://www.frankmain.qpg.com/  has a lock on tubes about as Buchanans does on spokes and rims.
I would bet the Cycle-X tubes come from Frank's truth be told. OCICBW
I think you'll find a set of tubes is more like $225+, unfortunately they don't list prices on their webpage, which is merely a tombstone add and contact page.
But that's what I paid for a set and that was many years ago. IIRC
PS: I see Cycle-X tubes at about $150 +/-. Mine may have been so expensive as they were K1 tubes which have a lot more machining on them,  So scratch the $225 for $150 +/-. At that price, extenders lose all attraction.
« Last Edit: November 26, 2010, 06:16:42 AM by MCRider »
Offline Tintop
Re: fork extensions
« Reply #10 on: November 26, 2010, 06:58:04 AM »
Looked up my invoice from Frank's for my 550 tubes - $249US including shipping from Illinois to Canada.
77 CB550 Cafe build
Hinomaru
Re: fork extensions
« Reply #11 on: November 26, 2010, 07:28:03 AM »
Just to add with the others about fork slugs ...
The problem with slugs is that while the lower portion of the steering stem has a firm grip on the fork tube, the top clamp had only a loose hold on the slug. This left the majority of the fork's length unsupported. When fork tube flex occurred, the threaded, unsupported joint between the slug and fork tube acted as a hinge and eventually broke.
Old school Harley Davidson owners were able to "get away" with using slugs on the original (Made-in-USA) wide glide fronts ends and ONLY if the slug was located between the top and bottom tree. Slugs that extended below the bottom tree often broke giving them a (rightfully so) unsafe reputation.
Offline borzwazie
Re: fork extensions
« Reply #12 on: November 27, 2010, 10:10:49 AM »
too bad you're only needing an inch or two - I have a decent set of what I believe are 8" overs in my garage - the PO of my '78 was going to make a chopper. cut up a *perfect* 4-into-1 to make drag pipes... >:(
Re: fork extensions
« Reply #13 on: November 27, 2010, 10:14:42 AM »
A good machine shop could cut those down, I think.
Offline Hannibal Smith
  • 3rd Grade Dropout
Re: fork extensions
« Reply #14 on: November 27, 2010, 11:54:26 AM »
I just got a set from "Franks" and they were $240.00+-
Worked just perfectly, but they were of stock CB550 length-
Follow my build "P38 Racer" in Project section
Re: fork extensions
« Reply #15 on: November 27, 2010, 12:28:59 PM »
 I probably have made them, and certainly can....just dont like promoting them.
 That said, anyone trying to make their own, of you cannot accurately cut metric threads on a lathe, and the machined portion for the O-ring, then its best left alone..
Offline 78 k550
Re: fork extensions
« Reply #16 on: November 27, 2010, 04:15:46 PM »
i have extended forks what length? pm me
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
dcil
Re: fork extensions
« Reply #17 on: November 29, 2010, 06:23:36 PM »
not sure of exact length yet. once frame is hardtailed, and neck is raked (around 40 degrees) I'll know more. I want to keep it level, or close. 21 inch front wheel and stock 18 inch in the rear.
Re: fork extensions
« Reply #18 on: November 29, 2010, 07:37:59 PM »
Grab the 8 overs..
Offline Jaroldoe10
Re: fork extensions
« Reply #19 on: June 08, 2020, 03:48:52 PM »
Anyone here still have fork extensions to sell? 8 inches sounds about right for me. Thx
Re: fork extensions
« Reply #20 on: June 09, 2020, 05:48:08 AM »
I have a pair of fork pipes, they are loooooong.  I got them while back but could not find anybody to shorten them for me.  If interested, I can measure them for you.   Let me know.
Offline Jaroldoe10
Re: fork extensions
« Reply #21 on: June 09, 2020, 06:04:49 AM »
Yes please measure them and what's your price sir
Re: fork extensions
« Reply #22 on: June 09, 2020, 07:22:54 AM »
I had as many others longer pipes for many years ago on my CB750K6. 6" longer than stock.
They were chromed all over making it possible to skip stock ears and gators. Stock pipes had rusty upper part
This brings oil seal replacement too.
Good time to service the forks, cleaning them and replace the plastic piston rings inside if CB550 are like the CB750.
This will not improve handling ;)
Re: fork extensions
« Reply #23 on: June 10, 2020, 05:08:29 PM »
Sorry, took me a while.  I believe the tape marks the length of a normal fork.
« Last Edit: June 10, 2020, 05:10:09 PM by 70CB750 »
Offline Jaroldoe10
Re: fork extensions
« Reply #24 on: June 11, 2020, 08:40:43 PM »
Awesome! I could not find this thread for the life of me. Please message me so we can talk. Thank you
