Author Topic: cb750 cylinder NO 1 puking oil not firing with fresh rebuild arrrgggg  (Read 3181 times)
cbfreaky750
hi my newly restored cb750 is not firing at cylinder no 1 the compression was normal and it has new valve guides spark plugs but it just does not get hot i can still touch it with my hand 5 minutes later. there is black oil is coming out of the exhaust around the header and splattering all over the engine also the oil gets dirty real fast what could be the problem
cbfreaky750
Re: cb750 cylinder NO 1 puking oil not firing with fresh rebuild arrrgggg
« Reply #1 on: March 16, 2006, 12:37:30 PM »
here is a pic of the oil
Offline hcritz
« Reply #2 on: March 16, 2006, 12:49:25 PM »
Hey CB...
Is it actually oil or could it be fuel?
cbfreaky750
« Reply #3 on: March 16, 2006, 12:52:18 PM »
it could be a mix of both but i would say its mostly oil
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #4 on: March 16, 2006, 12:58:34 PM »
I would think that if that much oil (or mix) is getting into the cylinder and to the exhaust, the plug is fouling and that's why it's cold. The lack of fire could be a symptom. I would focus on how all that is leaking in there.
cbfreaky750
« Reply #5 on: March 16, 2006, 01:12:20 PM »
I dont understand where the oil is or mix is coming from i was thinking a rings could be stuck. The compression of is 150psi though and the valve seals are brand new also the carbuerators are completley rebuilt i did however tighten the air screws becouse of the drag pipes made it lean could it be way too rich??
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #6 on: March 16, 2006, 01:18:10 PM »
By tighten, do you mean fully seated??
Offline JHansen
  • In a word... breathtaking
« Reply #7 on: March 16, 2006, 01:23:04 PM »
Only a theory, but perhaps a leaky head gasket? Oil getting into the cylinder, fouling plugs, then mixing with unburned gas and leaking out? Are you sure the head was torqued down properly?
'76 CB400f -cafe'd out
'75 CB400f -future project waiting in wings
'03 Yamaha V-Star Classic
'90 Honda VFR 750
Offline hcritz
« Reply #8 on: March 16, 2006, 01:23:21 PM »
I would make sure that it's not mostly fuel...that could wash down the cylinder and ruin your fresh rebuild on that cyl.
The floats seem to be notorious for sticking! Normally that would run out the overflow...pinched tube???
Have you tried a fresh plug and check for fire on that cyl.?
cbfreaky750
« Reply #9 on: March 16, 2006, 01:29:13 PM »
Well I must have fully seated the air screw too much i backed it out 3/4 of a turn and now its gets hot enough to burn my spit off hurray the plug is a little oil fouled now but its not too bad i put a set hotter plugs in becouse all the plugs are a little oily it seems to help alot also the head was properly torqued down in sequence. i have a clymer manual with the torques
Offline dusterdude
« Reply #10 on: March 16, 2006, 01:35:39 PM »
groovy
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline hcritz
« Reply #11 on: March 16, 2006, 01:36:31 PM »
Good Deal!
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #12 on: March 16, 2006, 01:37:40 PM »
Glad to hear it was that simple. Good riding.  ;)
cbfreaky750
« Reply #13 on: March 16, 2006, 01:53:42 PM »
thanks alot for your quick suggestions im glad its runs after all its been through
Offline Big Jay
    • CBRzone
« Reply #14 on: March 17, 2006, 05:15:03 PM »
Were both of the tiny oil jets still in the head when you put the rocker stands on? If not the head will fill with oil and go down a valve stem, new seal or not.
