I'm pretty confident in getting my 550 back up and running. It's sat outside, uncovered for the last 30 years untouched, but despite that it's in pretty good mechanical condition. I'm confident in most of the stuff that needs to be done, but I will freely admit that I suck at all things electrical.
So a few questions:
1. I assume after 30 years of sitting outside in the weather most, if not all of the electrical on the bike is toast? Most the wiring casing is brittle, the connections are all corroded, ect. Even if it's not is it a better idea to just upgrade to more modern electrical?
2. Are there replacement kits available to wire up a bike from scratch, generic or otherwise? I've searched but haven't found much of anything.
3. I'm only interested in the minimum electrical I need to run the bike and pass VA inspection. For the inspection all I need is headlight (high/low), brake light, neutral light, and a horn. Push start would be nice, but I really don't care about not having one. If I can't get a kit how hard is it to wire everything from scratch without a kit or would I just be better off having a shop wire up the few things I need?
