How it stands right now.
![](http://i152.photobucket.com/albums/s172/joeband/7.jpg)
Just put the engine back in.
New wiring harness and carb going on tonight. All of the wiring in the controls is shot, so maybe that tonight as well.
I feel as though there is a mystery unveiling here though. There is alot of evidence that someone had maybe restored the bike...30 years ago and didnt get it running.
clues
![Shocked :o](http://forums.sohc4.net/Smileys/default/shocked.gif)
#1) there was a run in the silver paint on the rear fender.
#2)Black paint on wiring harness (I have seen others with paint on them as well though) Did Honda paint these bikes with the harness installed?
#3) When I removed the chain sprocket cover.....it was immaculate. zero grease or grime. (the odometer says 16K) and the PO told me that the bike was used as a dirt bike in the early 70s.
#4) When I dropped the motor I found that the plug on the harness for the ignition was plugged into the engine and the plug that was supposed to be plugged into the engine had the ghetto anti ignition (pictured here earlier)
I think that one of the kids that took it apart 30 years ago restored it then switched those wires by accident and then never got it running again. Not 100% but still a good tale.
Before anyone want to correct me about the harness- there were 2 styles avai for the S90. One had just 2 wires that went to the ignition and the other was a 6 pin plug just like the one that comes out of the engine.
