Author Topic: What do you think about these fork tubes?  (Read 1050 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
« on: December 06, 2010, 12:23:42 PM »
Both of 'em are pitted like this. Is that something critical? Is there an easy way to remove the pitting, or should I look to replace? What do y'all think? BTW - not SOHC4 I know....  :)
Offline wookie
  • I would get up if i knew i fell
Re: What do you think about these fork tubes?
« Reply #1 on: December 06, 2010, 04:34:15 PM »
If the pitting goes all the way down it will wear your seals.  Get a new (or good used) set, pitting is in the chrome.
dcil
« Reply #2 on: December 06, 2010, 05:38:34 PM »
Try some fine steel wool and wd40 and see what they look like when your done. My old zuki forks were worse looking than that when I started. They polished up perfectly with no pits.
