Author Topic: Happened upon an AGM battery  (Read 1839 times)
Offline Motoguy23
« on: December 07, 2010, 10:32:21 PM »
Hey guys,
My friend was cleaning out his basement and found a small AGM battery and I was wondering if that would be enough to run my bike on.
You can see it here: http://www.batteriesplus.com/pc-32755-32755-XTAX4L-BS.aspx
Its only 3Ah and 50CCA.  The CCA doesn't bother me because I only use the kick starter and I don't use blinkers.
Do you think I would be good or do you think it would die while waiting to go at a red light?
All glory to the hypno-toad.
Offline Alan F.
Re: Happened upon an AGM battery
« Reply #1 on: December 08, 2010, 06:50:02 AM »
Which bike? And are you running a stock ignition system? (points and original coils)
Sounds low on the amp/hours, but might be alright generally speaking. Maybe add an on/off switch on your headlight if you don't have one, or run a low wattage headlight.
KingCustomCycles.com
« Reply #2 on: December 08, 2010, 06:56:37 AM »
Many know more than me on this but the battery is rated at 3 amps discharge for an hour.  I know most don't actually deliver their rated capacity, and the numbers are extrapolated from very low discharge rates, but at 1/2 rated capacity, you would still be able to draw over an amp for an hour with the bike not throwing a charge back in at all.  Charge rate might be an issue at that capacity.  I believe it will accomplish what you want out of it. TT?
« Reply #3 on: December 08, 2010, 07:46:57 AM »
It is certainly not a problem with a 5.5 amp, so it may work.
 Check you local laws though some require, lights on without motor running, that may be an issue. I think you will not want a high draw headlight.
 I did mean for a CB750, the 500/550 seems to have charging issues, so not sure on them
Offline Motoguy23
« Reply #4 on: December 09, 2010, 12:11:57 AM »
Sorry I didn't give the bike details.
My bike is a CB00 and the charging system is stock but I have Dyna ignition and coils.
What kind of headlight would you suggest?
« Reply #5 on: December 09, 2010, 12:23:14 AM »
You shouldn't have a problem as a
CB00
obviously doen't have much of an engine  ;D  Maybe you can specify how many cc you would like to ignite. Try again, please.
« Last Edit: December 09, 2010, 12:26:32 AM by Deltarider »
Offline Motoguy23
« Reply #6 on: December 09, 2010, 01:27:33 AM »
CB00
Maybe that's why there are pedals on it...  I should have done my research before I bought it huh?
What I MEANT to say is CB500
« Reply #7 on: December 09, 2010, 07:08:29 AM »
 I got to warn you, some electronic ignitions need at least 10V to fire, if your battery is on the small side there is a far greater chance you will run into a low voltage/no start issue..
Offline A350- 4 me!
« Reply #8 on: January 06, 2011, 10:57:52 AM »
I would agree on that, I have a 5amp battery used for alarms and I've been having that probably, you just need to kick harder..
