I just picked up a '75 CB750K and was wanting to pull and check the plugs.
My first issue is getting the center 2 out, since I don't have the oem tool kit. My second issue is that the plugs that are in there now are Champions with a 16mm head on them, and from reading through the FAQ section they should be a 18mm no? I am NEW to motorcycles, all together, so I have a bit of a learning curve.
Chris.
