Author Topic: 74 cb550 in the frozen tundra....Damn near done!  (Read 64256 times)
Offline Bakeoff
Re: 74 cb550 in the frozen tundra....Damn near done!
« Reply #200 on: August 07, 2011, 12:09:32 PM »
I recirced the PCV tube into the air box yesterday and I'm playing with carbs and ignition timing today.  Just got a few other little issues to work out!
And the coolest news is I was nominated for bike of the month on here.  Super stoked!  I'm definitely going to take up one of my photographer friends on the offer of a photo shoot. :)
Offline Bakeoff
« Reply #201 on: August 09, 2011, 10:11:21 AM »
I just wandered out to the garage to have a smoke and discovered both front brake calipers are leaking at the banjo bolts.  It looks like with this design, going to a banjo instead of a normal flare fitting, the banjo fitting presses on the caliper housing causing the crush washer to not seat fully.  So, a slow leak has lifted almost all of the paint on both front calipers...  Bleh!  I'll double up crush washers to fix it, but I'm not psyched to repaint calipers....again.
Offline Aladinsane07
« Reply #202 on: August 09, 2011, 12:04:06 PM »
Damnit.  I JUST ordered new lines, banjos, and crush washers and convinced myself I wouldn't have a need for extra crush washers. Let us know how you end up fixing the leak.  It will most definitely save me some trouble shooting and painting.
Offline Bakeoff
« Reply #203 on: August 17, 2011, 03:29:11 PM »
The brake fix was stupid...  The banjo bolts were too long, so they were bottoming out inside the calipers.  I ground them down and they look like they should work fine now.  I just have to repaint the calipers and I can get them back on.  Been busy with track days on the CBR.  :)
Offline ridered67
« Reply #204 on: August 19, 2011, 07:28:00 AM »
That thing is sweet!  Ive been thinking about ordering those same shocks off ebay. Are they good quality?
You may have already mentioned this but is that a spray paint job on the bike?  Im not knocking it, It looks killer.
Offline mrrch
« Reply #205 on: August 21, 2011, 10:02:55 AM »
Check that the sealing washers outside diameter is smaller than the recess on the caliper. I had a slight leak until I resized the sealing washer, now all is well.
my build
Offline sniper1
  • SNIPER1
« Reply #206 on: August 21, 2011, 12:54:33 PM »
Bakeoff,
Can you post some hi-def pics from all angles of your bike? I am working on a build similar to yours. I may be hitting you up with some questions as well.
Thanks,
Offline Bakeoff
« Reply #207 on: August 23, 2011, 06:55:21 AM »
I don't have a ton of miles on the bike yet.  But from what I can tell, they function well.  Only time will tell if they'll hold up.  For the price, I took a chance.  I'll report back once I get some real miles on it.
I went a step farther and ground the top smooth, then shortened the banjo bolts.  So far, so good.
Bakeoff,
Thanks,
I don't have any yet.  Its been a busy summer and I haven't had a ton of time to work on it or ride it.  I'm talking to a couple photographer friends about setting up a shoot.
Offline Bakeoff
« Reply #208 on: September 06, 2011, 09:41:52 AM »
I noticed a guy at Dulano's (the host a local bike night once a month) taking a photo of the bike and asked if he could email it to me.  Glad I did!
Offline BeSeeingYou
« Reply #209 on: September 06, 2011, 05:24:32 PM »
Saw your bike at Dulano's the other night.  You did a nice job.
« Reply #210 on: September 07, 2011, 08:10:37 AM »
Pics of her completed.  Well, almost...  I'm stopping by Honda Town tonight after work to get a replacement front brake switch.  Then I think she's pretty well wrapped up.
What a beauty!
and inspiration
« Last Edit: September 07, 2011, 08:23:54 AM by 70CB750 »
Offline RC51rydr
  • 1973 CB750
« Reply #211 on: September 11, 2011, 06:17:56 AM »
Great job! Looks amazing!
CB750K3
Offline Bakeoff
« Reply #212 on: September 15, 2011, 01:46:56 PM »
I'm waiting for a brake caliper seal to come in, so the bike is back off the road...  Both front calipers were hanging up, so I decided I'd rebuild them. In the mean time, I threw a quick video together of some footage I took on a quick ride one day after work.  Nothing special, but kind fun...
74 compilation.wmv
« Reply #213 on: September 15, 2011, 09:08:45 PM »
Dude, awesome!  Seriously awesome.  I've never seen a 550 with clip-ons from that point of view.  I love it.
Offline bluesmoke69
« Reply #214 on: September 15, 2011, 09:21:06 PM »
Bike looks great!!
Offline Bakeoff
« Reply #215 on: September 15, 2011, 09:31:17 PM »
Thanks guys!  Once the darn brake caliper seal comes in, I'll be back on the road!  I was out at Dulano's this month and I'm hoping to make it out for First Thurs this month as well since it will probably be the last of the year..  I've got a track day Oct 2nd at DCTC that I need to prep for, but if things work out, I might bring this thing to the track and take a few laps with it.
Offline sniper1
  • SNIPER1
« Reply #216 on: October 15, 2011, 06:01:45 PM »
How did you make your seat? How is the pan attached? Can you easily remove it to get at battery, air filter, etc.? I really like the way it looks, and may try to copy.
Offline brettster26
« Reply #217 on: October 15, 2011, 06:08:06 PM »
Also how do the RFY shocks work?  Was thinking about getting some for my build. If you could get back at me that would be great!
Thanks
« Reply #218 on: October 15, 2011, 06:41:15 PM »
Bake - you been at the track all this time?!
Offline Bakeoff
« Reply #219 on: October 15, 2011, 08:24:51 PM »
I ended up picking up a track bike, so if I do go down on the track, I won't wad up nice street bike.  In the mean time, I waited almost three weeks for Bike Bandit to send me the caliper seal...  "In stock" apparently means "we'll order it from Honda and then send it out."   Argh!  I threw in the new seals and threw everything back together.  I swapped over to DOT 5 fluid, so if i had any leaks, it wouldn't strip the paint again.  While bleeding the brakes, I noticed a leak at one of the banjo fittings.  Gave it another little crank and it stripped the threads out of the caliper.  Turns out the threads on the banjo bolt were less than stellar.
At this point, I have another caliper I can rebuild.  I'm going to try to get it done this week so I can get out on her at least once more before the end of the season.  There may be some changes over the winter.  I'm still trying to decide if I want to throw a modern front end on it.  And if I do, go with modern wheels to make brakes easy or try to do something like Thruxton wheels on it so I can get some decent tires on it. I almost like the idea of keeping it as is, but goddam, those front brakes suck.  Even with the dual conversion, they're terrible.  Old pads?  Crappy technology?  I'm not sure what to think yet.
« Reply #220 on: October 15, 2011, 11:14:18 PM »
Throw a pair of new EBC pads on it before you move over to a new front forks. What kind/size of master cylinder do you have on it.  The stock MC is the wrong size for dual front calipers.
David
Offline Bakeoff
« Reply #221 on: October 16, 2011, 09:23:26 AM »
I have a master from a 93ish CBR.  I'll probably order a set of pads tonight.
Offline lucky
« Reply #222 on: October 16, 2011, 11:07:34 AM »
You must be a Scorpio? All those bikes - relationship problems  etc.,.LOL
Offline Bakeoff
« Reply #223 on: October 16, 2011, 11:27:57 AM »
Capricorn.  Are you hitting on me?  lol  Half the women I've dated were Scorpios.  I've learned to stay away at this point!
« Reply #224 on: October 16, 2011, 11:22:50 PM »
Bakeoff, I thought you were the one who said something about feeding trolls and then there you go and do it.
What Scorpio's have relationship problems?
David
