Author Topic: Vintage Motorcycle Pics  (Read 71769 times)
Offline MoMo
  • Ride like you're invisible
Re: Vintage Motorcycle Pics
« Reply #225 on: March 16, 2011, 10:26:16 AM »
This recently made its way into my garage and I think it qualifies as vintage.  1949-ish frame and motor with some later parts here and there.  No swingarm on this baby... I may need a kidney belt.
Awesome find.  Was it cruising down the street and made a turn into your garage?  More info, please...Larry
Offline weekend_junkie
  • I bet you think I'm some
  • Member # 15859
« Reply #226 on: March 16, 2011, 10:51:47 AM »
This is good quality motorbike, best parts from great soviet nation of Russia.
Not much story that I can tell you, as this is the first non-Honda bike I've ever owned.  I've been learning a LOT from sovietsteeds.com and learned that it is a congolmeration of 'newer' (ha!) bodyparts but apparently a VERY early 1st generation Russian frame and engine, komplete with a reverse gear that appears to simply be missing a lever.  I need to do some title work (I live in NJ so wish me luck), get a 6V battery, and tune her up.  I got it from a guy who says that he bought this because he couldn't find a reasonably priced US Army Jeep.  Now all I need to do it find a way to get an open carry permit for a machine gun on the sidecar...
In Soviet New Jersey, hobbies work on YOU!
Dan
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #227 on: March 16, 2011, 11:02:28 AM »
If you succeed  ;) you might want to not plan any road trips to Fort Dix.  ;D
Offline Stretch
  • They ain't all dirt roads!
« Reply #228 on: March 16, 2011, 05:10:46 PM »
Love this bike, 1934 Crocker...
If you're in Maggie Valley NC, the Wheels of Time motorcycle museum has one. If its open and you stroke the owner/owner's son, he'll do a 40' burnout right through the middle of the museum. I was there a couple years ago and he said they had taken it to the dragstrip the year before and won the class. IIRC he said it puts out about 90hp, it was built to beat the Indians and Harleys.
Last year the museum was only open selected weekends so call ahead.
'78 CB750K
An assortment of Hondas, mostly V4s
Offline Jordan
  • What a Long strange trip it's been
« Reply #229 on: March 16, 2011, 05:22:02 PM »
At the end of WWII the Russians pretty much dismantled the BMW factory and took it back the the motherland as war booty. They and the ChiComs have been making them there pseudo-beemers ever since. At least that's what the history books say.
Offline MoMo
« Reply #230 on: March 16, 2011, 05:35:17 PM »
That's what I hear, took everything to the Ural Mountains, hence the name...Larry
« Reply #231 on: March 16, 2011, 08:28:36 PM »
That's a plunger-type rear suspension. The axle moves up and down on coil springs, but there is no damping, save for friction. My '53 BSA twin had the same type setup.
  • Member # 15859
« Reply #232 on: March 17, 2011, 07:45:16 AM »
This tells a slighty different version, but you know what they say about history book authors!
http://www.imz-ural.com/factory/
Dan
Offline MoMo
« Reply #233 on: March 17, 2011, 05:05:21 PM »
Seems like the Russians either dismantled the plant or bought some motorcycles and dismantled them-either way they stole the design.  Did the same thing with Leica and Hasselblad cameras :o  :o...Larry
Offline Uncle Ernie
« Reply #234 on: March 18, 2011, 10:37:14 PM »
Well... much of that is in shadow on my old computer, but I'd bet a nickel that's a Chang Jiang.  Lately eBay is packed with Changs being passed off as BMW's, too.
Good luck getting a title, and don't plan any long rides,
and "NO"- none of the parts interchange with BMW.
Big hug now -  ;D
Offline Uncle Ernie
« Reply #235 on: March 18, 2011, 11:02:35 PM »
Anyone think this one is real?  ;D
_____________________________________________________________________________________________
Just a guess..but I'd say it's not actual/real.  The locomotive looks to be an early 1900's Baldwin..and the bike a teens vintage..
The state of photography then wasn't advanced enough to capture stop action like that..I believe.  The motorcycle would have been quite blurred..if it was going fast enough to make that jump.  The landing angle seems a bit low also.  My guess: that the bike pic was superimposed on the locomotive pic.
Be interested to see what others "analysis" of the pic is..
Ichi
Going back a ways here;
First of all, they didn't have computers- they did work in the darkroom.  That could easily be a double negative or the surounding area being so clear, it could easily be burned in- especially if they were using a larger format negative like 4x5 or 8x10.
However, it would be quite easy for someone with knowledge of modern technology to add the bike and make it look original.  For instance, who would assume this is completely Photoshopped?;
« Last Edit: March 18, 2011, 11:06:14 PM by Uncle Ernie »
Offline Uncle Ernie
« Reply #236 on: March 18, 2011, 11:15:56 PM »
I was a float in our local Mardis Gras parade;
Gee.  Come to think of it- I'm older than my so-called "vintage" motorcycle...
Offline faux fiddy
  • bike in a box
« Reply #237 on: March 19, 2011, 02:47:09 AM »
My friend's uncle- Probably about 1941. No photoshop here, that's a real faring.
« Last Edit: March 19, 2011, 02:48:44 AM by tree fiddy of industry »
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
Offline faux fiddy
  • bike in a box
« Reply #238 on: March 19, 2011, 02:51:38 AM »
Another inherent problem with the design is that the springs don't compress at the same rate on both sides, causing the axle to tilt.
« Last Edit: March 19, 2011, 09:04:00 AM by tree fiddy of industry »
Offline Uncle Ernie
« Reply #239 on: March 19, 2011, 04:53:34 AM »
I drove a BMW R67/2 sidecar rig from San Francisco to Montana, and the frame was similar.  No problems in the handling department at all.  In fact, I feel the plunger-framed rig was the best handling sidecar set-up I've ever driven.
« Reply #240 on: March 19, 2011, 09:31:29 AM »
 I assume that was with Earls type forks?.. they work well with hacks..
Offline Uncle Ernie
« Reply #241 on: March 19, 2011, 03:09:58 PM »
The Earls fork was from 1955 to 1968.   There is debate regarding who introduced telescopic forks to PRODUCTION bikes first;  Nimbus or BMW.  Obviously, BMW had biger numbers.
An example of the bike is on page 2 of this thread;  1952  R67/2  (600cc)
The actual rig is pictured on page 2 (with me in the blue coveralls), and here;
  • Member # 15859
« Reply #242 on: March 20, 2011, 07:53:55 PM »
Big hug now -  ;D
From all I have read so far, you owe me a nickel.  The perfect triangle trusses (#1 why not a Chang) in the rear of the frame are an exclusive 1940's Russian design improvement from the original BMW cloning for the severe terrain.  Also, the motor is an EARLY M-72 motor with 6V electric and reverse (incredibly rare and #2 why not a Chang).  Lastly, the head looks like the Chang head and that may have been what tipped you off, but it is different because it is fully vented whereas the Chang has a solid face on the head.
BUT I'd be happy to see what info you have if it says otherwise.  It's a real adventure just learning about this bike.
Dan
Offline Uncle Ernie
« Reply #243 on: March 20, 2011, 10:16:10 PM »
If you Google "Jimbo'sSidecars", this man spends tons of time in China and his business is taking the Chinese frams and putting BMW lumps in there.
If you research Chang Jiang, you will note the frame gussets just fore of the plunger shocks.  the heads look the same (to me anyway) and they also share what looks similar to old Bing carbs.  The examples on eBay recently have the same tank and control levers.
Usually they're offered as BMW R72.
Here's a picture of one of Jimbo's customs using the stock engine.  Is it different from yours?  As i said- my screen is pretty dark, so I miss some details.
http://www.changjiangunlimited.com/2007-B/07-0612-Jim-1001.jpg
  • Member # 15859
« Reply #244 on: March 21, 2011, 07:00:56 AM »
Yep, different on all counts.
Dan
Offline Jordan
« Reply #245 on: March 21, 2011, 09:20:31 AM »
Offline Uncle Ernie
« Reply #246 on: March 21, 2011, 04:06:07 PM »
Being involved with sidecars for almost 40 years, I'd like to learn something here.
Is there any way I can get a bigger sideshot of that rig that's reasonably well lit?
Send it via e-mail even.
  • Member # 15859
« Reply #247 on: March 21, 2011, 05:29:34 PM »
Sure thing, I'll have to snap a few for you.  My bike garage is 'off premises', so you'll have to wait until the weekend.  I've only been doing the sidecar thing for about year, but this already my third rig!
I'll include a link to my discuss thread over at SovietSteeds in the mean time:
http://sovietsteeds.com/forums/viewtopic.php?f=12&t=16260
Dan
Offline Uncle Ernie
« Reply #248 on: March 21, 2011, 07:02:59 PM »
Good read there.  So i was sort of right sometimes...  ;D
It's a bitsa according to those folks.  When I get those side shot's, I'll submit the body to my own set of forensic mechanics.  They are currently in quite an uproar about Changs advertised as M-72's or other BMWesque rigs- right down to the paint jobs and tank badges.
« Reply #249 on: March 21, 2011, 11:36:51 PM »
indiana jones escaping on a monopede?
