Author Topic: wiring diagram needed  (Read 865 times)
Offline Scott
  • 72 CB750
« on: December 20, 2010, 12:47:23 PM »
I need to do a bit of diagnostic work and wiring up of a bike that was partially pulled apart 20 years ago.  Is there a wiring diagram that is better (easier to follow ) than others.  I have ordered that book from a bloke on this site a few days ago but I reckon it's going to take a couple of weeks or more to get here and I would love to make a start now.
Thanks  Scott
Offline george
  • Back To My Roots !
  • K8 The Project
Re: wiring diagram needed
« Reply #1 on: December 20, 2010, 04:39:51 PM »
This is pretty neat, hope it helps.
http://oldmanhonda.com/MC/wiring750K1.html
Found this bike in completely stock condition in Feb. 08. Paid over twice what my new one cost 30 years ago. Am trying to re-create the look of the late 70's Drag Bike styling.More later. 4-2-10 It ain't stock any more and I have no idea what I am trying to create !
Offline Zaipai
    • My Home page
« Reply #2 on: December 20, 2010, 04:45:54 PM »
+1 used this one, its pretty good!
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline MoMo
  • Ride like you're invisible
« Reply #3 on: December 20, 2010, 04:56:12 PM »
That schematic is an awesome piece of work...Larry
Offline george
  • K8 The Project
« Reply #4 on: December 20, 2010, 05:28:57 PM »
.: Scott :.
Except remember to add the clutch sw and the diode on later models, you know that little diode is a tricky rascal!
Offline Scott
  • 72 CB750
« Reply #5 on: December 20, 2010, 07:47:39 PM »
mate that is excellent thank you
I may allready be able to spot a potential problem
My starter solenoid is not working on the bike.  On the work bench no worries and I'm getting power to it when pressing the starter button,  but I am missing the horn maybe thats a problem as I see it is linked or I might just be tripping and talking rubbish.  Time will tell, but thanks again dude
Scott
Offline george
  • K8 The Project
« Reply #6 on: December 21, 2010, 06:57:49 AM »
  Hey Scott, what model , year is your machine, there is a few changes over the years, especially ones with the clutch safety switch . It really is very simple once you understand how each circuit is laid out. When I start with an unknown bike with some ghost in the machine, I find most probs are caused by corrosion,first, and PO mods second, especially if it had one of the very popular large touring fairings that required mods in the headlight  and signal area.
  I use a very simple test light and two jumper wires, one for hot and one for ground, just bypass the harness and connectors, then it is a process of elimination. I clean the connectors with a very small file and a can of carbon tet (contact cleaner). The bar switches will be unbelievably gunky, careful with the cleaning here. I have two horn button springs hiding out somewhere in my shop!
  Here is a K8 that we gave up on and built a totally new harness, adding modern electrics.
  Enjoy!
