Author Topic: Valve Lapping - Leak Test - Still leaking  (Read 17347 times)
FeroxJB
« on: December 24, 2010, 12:00:57 AM »
So.. I've lapped all the valves in the top end and put all the springs back on.. and after several LAPPINGS.. I can't get two of the exhaust valves to pass the leak test.
I'm pouring gasoline in the port with the head on it's side for the test..
It's not a huge amount.. just a small tidbit.. but almost immediately.
Any suggestions?
Should I consider buying new valve stems?
Also.. whenever I was cleaning them.. these two exhaust valves specifically had a lot of carbon build up on them.
76' CB 550F
« Last Edit: December 24, 2010, 12:32:29 AM by FeroxJB »
Offline trueblue
Re: Valve Lapping - Leak Test - Still leaking
« Reply #1 on: December 24, 2010, 12:38:03 AM »
Sounds like you need to get the seats recut and the valves refaced
1979 CB650Z
FeroxJB
« Reply #2 on: December 24, 2010, 12:57:14 AM »
Ugh! how much is this going to cost me?
Offline trueblue
« Reply #3 on: December 24, 2010, 01:11:50 AM »
I cant comment on that in your neck of the woods but at the shop where I work it is about 15bucks per valve to face the valve and recut the seat
1979 CB650Z
Offline faux fiddy
  • bike in a box
« Reply #4 on: December 24, 2010, 01:25:03 AM »
That's pretty reasonable, It shouldn't be hard to find a friendly shop in Texas that would do the same.
I think there are jigs you can by for DIY, too.
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
Offline MoMo
  • Ride like you're invisible
« Reply #5 on: December 24, 2010, 01:50:41 AM »
The angles of the cutters are very specific to each model of Honda, make sure that whoever you choose to do the work is familiar with Honda's.   15 is awfully cheap, we charged that per seat back in the  80's.  You could have a bent stem, guides would have nothing to do with fluid coming out at the seat...Larry
Offline trueblue
« Reply #6 on: December 24, 2010, 02:07:43 AM »
We cant afford to be any dearer, we are a small shop in a town of about 25 thousand with 2 other engine shops in town so competition is pretty fierce, and honestly it only takes about 10 minutes per valve to do.
1979 CB650Z
Offline MoMo
« Reply #7 on: December 24, 2010, 02:14:56 AM »
[/quote] We cant afford to be any dearer, we are a small shop in a town of about 25 thousand with 2 other engine shops in town so competition is pretty fierce, and honestly it only takes about 10 minutes per valve to do.
[/quote]
That is refreshing honesty...Larry
FeroxJB
« Reply #8 on: December 24, 2010, 02:38:50 AM »
After much much lapping.. it seems like it all but stopped.. maybe a SMIDGE.. but nothing like it was.
Offline faux fiddy
  • bike in a box
« Reply #9 on: December 24, 2010, 02:51:14 AM »
I always say keep at it until you get hungry and have to go eat.
« Reply #10 on: December 24, 2010, 05:49:47 AM »
I'll say. Most shops use a Serdi or something comparable.
« Reply #11 on: December 24, 2010, 05:54:17 AM »
Are you lapping by hand or with the power drill method?
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #12 on: December 24, 2010, 08:27:59 AM »
A little trick I did that seemed to give a nice lap with reasonable effort was to use a conical spring (not much, a few Newtons should do it) and the T-handle from my tap set.  Insert the valve into the guide, a little lap compound on the face.  Spring over the stem, a little electrical tape on the stem where the T-handle clamps on.  The spring presses the valve to the seat.  finger-spin it clockwise for a bit, then counter-clockwise for a bit.  Fresh compound and repeat.
Gave me a nice even, dull gray band on the valve and seat in no time!
FYI, it is VERY important that the valves are lapped into the seat from which they came.  Don't mix valves between cylinders!!
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
FeroxJB
« Reply #13 on: December 27, 2010, 07:44:20 PM »
Its got a nice shiny band around the valve.  It still doesn't seat very well however.
« Reply #14 on: December 27, 2010, 08:29:47 PM »
i use rubber hose on the stem and pull it back with a varible speed drill slowly,changing  direction once or twice,counting ten each time.
Offline faux fiddy
  • bike in a box
« Reply #15 on: December 28, 2010, 04:34:06 AM »
I like to just use my hand. After a few turns back and forth you can feel that the paste is just sliding instead of cutting. I like to be able to feel some grit doing it's thing, and just spinning with a smooth feeling probably doesn't do as much.
Amd there are different grits of valve grind solution, I'm sure you know...
srook
« Reply #16 on: December 28, 2010, 07:07:29 AM »
Lapping is not a cure all and no substitute for a valve job.  Your exhaust valves probably have pitting and if so all the lapping in the world won't allow them to seal.  I would suggest getting new valves as well.  I am also into classic British bikes and no one in the Brit bike world lapps valves or if they do they keep it a secret.  I think it has to do with the initial cost of ownership being lower for Japanese bikes.  Ask yourself why you are rebuilding the motor?  If you want to build a reliable engine that runs like it should then put the lapping sticks and compound away and get a valve job.  Yes it costs money and I would probably insist it was a serdi valve job.  Not trying to sound harsh but do it right the first time or do it over again, your choice.
Scott
« Reply #17 on: December 28, 2010, 07:31:58 AM »
That's the ticket in my mind. That should make quick work of it. Now, if the stem to guide clearance is too high, you may have a situation where you're not going to get a consistent seal without new guides. That's a different issue from the efficacy of lapping which should work fine if the guides are OK.
With the drill you can feather the pressure on the grinding compound to whatever degree you want.
If you need guides, you'll need a valve job.
« Reply #18 on: December 28, 2010, 08:28:59 AM »
Any suggestions?
Should I consider buying new valve stems (seals)
76' CB 550F
Huh?
Offline faux fiddy
  • bike in a box
« Reply #19 on: December 28, 2010, 09:49:37 AM »
Scott
I figure if i'm in the motor because the rings were stuck an the valves look good, the valves are going to  get lapped in while it's apart. And you are accurate abut the initial investment ,too. A valve job would have cost more than the bike I was working on.
FeroxJB
« Reply #20 on: January 01, 2011, 10:48:15 PM »
Decided to go ahead and have it done at the shop.
I dropped it off at the machine shop a few days ago.  I should be getting it back this coming week.
Offline camelman
  • Man... Myth... Legend
« Reply #21 on: January 02, 2011, 01:56:59 AM »
You should definitely replace any valve stem seals before you reassemble.
Camelman
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
