"In addition the used ones seem to get stuck, and the pin no longer springs out."
A pencil torch, carefully applied, and a drop of ATF will free those up just fine. Work it back and forth with small needle nose pliers to get the ATF worked into the spring. The heat loosens the varnish and gum enough to get the solvent action of the ATF to work.
