Support the site. Your contributions keep this site running.
Thanks for the welcome, guys.TrueBlue, the direction arrow is right way round on that front tire, but it does not say if the arrow is for front or rear fitment. Rear tire has arrow saying "Rotation, rear fitment", so who knows. Seems to work ok.
Quote from: Hopper on December 27, 2010, 02:10:37 AMThanks for the welcome, guys.TrueBlue, the direction arrow is right way round on that front tire, but it does not say if the arrow is for front or rear fitment. Rear tire has arrow saying "Rotation, rear fitment", so who knows. Seems to work ok. Ok, the reason for me asking about the rotation of the tyre is that every directional tyre I have seen has the outside of the 'v' grooves in the tyre making contact with the road last. and by doing so they push the water to the outside. The way that one is fitted common logic would think that it would pull the water to the centre of the tyre, which isn't a good thing, that is the first one I have seen that is the other way around to the norm. What type of tyre is it?
Quote from: trueblue on December 27, 2010, 04:14:19 AMQuote from: Hopper on December 27, 2010, 02:10:37 AMThanks for the welcome, guys.TrueBlue, the direction arrow is right way round on that front tire, but it does not say if the arrow is for front or rear fitment. Rear tire has arrow saying "Rotation, rear fitment", so who knows. Seems to work ok. Ok, the reason for me asking about the rotation of the tyre is that every directional tyre I have seen has the outside of the 'v' grooves in the tyre making contact with the road last. and by doing so they push the water to the outside. The way that one is fitted common logic would think that it would pull the water to the centre of the tyre, which isn't a good thing, that is the first one I have seen that is the other way around to the norm. What type of tyre is it?Checked the Avon website and they say the directional arrow is the direction, front or back. So it is the right way round. whew, had me worried for a minute.But they do say this :IFG(Inverted Front Grooves)For the front tyre, a system pioneered by Avon in the late eighties and only now being adopted by the competition, resists 'stepped-wear' and cupping to deliver smooth handling throughout the tyre's life. By significantly reducing uneven tread wear, a further advantage of the IFG configuration is improved wet braking and shorter stopping distances.Opposite of what you would expect but apparently it is the Avon way. Go figure.
