Can someone please give me "chapter & verse" on what is or is not interchangeable between the K and F series engines please?
From what I understand, I believe that you have to use both the head and block (i.e all the top half) from one type together and that an F top end will fit a K bottom end and vice versa, is this correct? If so what are the reasons for not being able, say, to use a K head with F barrels? I have a few sets of what I believe to be F1 barrels and I am planning to get the iron liners replaced with aluminium ones and Nickasil plated, but I don't want to waste the cash if I need K barrels!
Is there any easy way to tell K & F heads and barrels apart (on a stripped engine)?
Also, I'm looking for a good set of F2 cases, (I need these for the bigger bearing on the output shaft). If the engine number begins 26*****, am I guaranteed these will be the right ones? Was this modification only on the F2 cases?
Thanks in advance guys.......
