Author Topic: Olivia's Face lift. 78 CB550 build.  (Read 92057 times)
Re: Olivia's Face lift. 78 CB550 build.
« Reply #475 on: February 08, 2017, 05:49:35 PM »
Olivia finally up on a plinth awaiting tuning of her 650.  Cam, get her ready for Spring!!
https://www.instagram.com/p/BQRA0WbheW_/?taken-by=rustyolive
Offline RustyOlive
  • rustyolive.com
« Reply #476 on: February 08, 2017, 06:23:26 PM »
Haha.well.. close to tuning. But yes. She's getting work done. Carbs are coming out again. The rubber intake boots are leaking. Got new ones coming soon. Hopefully that'll seal up the leaks.
« Reply #477 on: February 08, 2017, 10:09:34 PM »
Which year 650 engine are you using and which carburetors?
Offline RustyOlive
  • rustyolive.com
« Reply #478 on: February 09, 2017, 04:23:28 AM »
1981 CB650 motor.
Keihin PD50 carbs from 78 cb750.
Offline RustyOlive
  • rustyolive.com
« Reply #479 on: February 24, 2017, 07:51:29 AM »
So a few days ago I loaded up the bike and took it to my buddies at Flying Squirrel Motorcycles here in Toronto.
I needed another set of eyes on it, after many failed attempts to get her to fire on all four and idle.
It appears my carbs need even more attention than just new gaskets and o-rings and such. And new rubber intake boots. Possibly a clogged fuel rail and float bowl breather holes.
Friend of a friend lent us his sonic tank. So today I'm heading back to Flying Squirrel to take the carbs out again. Tear them down and dunk them.
Not much of an update I know. But baby steps. In the right direction I hope. Lol
« Reply #480 on: February 24, 2017, 08:40:23 AM »
Great to hear you are on your way to getting Olivia back on the road.
In the photo (on the lift), it looks like you might be getting chain rub on the top of the swingarm (there is what looks like wear on the paint where the chain passes over).  It could be grease or a trick of the eye.
Offline RustyOlive
  • rustyolive.com
« Reply #481 on: February 24, 2017, 08:49:54 AM »
Thanks.
No. There's no rubbing going on.
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
« Reply #482 on: February 24, 2017, 08:53:17 AM »
That's what she said.
Sorry, couldn't resist.
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
Offline RustyOlive
  • rustyolive.com
« Reply #483 on: February 24, 2017, 09:11:06 AM »
Till I came along. Lol
« Reply #484 on: February 24, 2017, 10:16:00 AM »
Thanks.
Makes sense.  On second look, the "marks" also go down the front of the swingarm so I it looks more like chain grease.
Offline RustyOlive
  • rustyolive.com
« Reply #485 on: February 24, 2017, 01:48:33 PM »
You referring to the reflection?
« Reply #486 on: February 24, 2017, 03:36:54 PM »
No, Cam. I was referring to the inner left diagonal tube portion of the swingarm, where it narrows to the mount width.  There's some greyish discoloration that I first thought might be wear marks.
I cropped you photo (attached).  See the grey portion right under the chain.
« Last Edit: February 24, 2017, 03:43:38 PM by CB750 Cafe Racer Fan »
Offline RustyOlive
  • rustyolive.com
« Reply #487 on: February 24, 2017, 03:49:18 PM »
Oh? Haha. No. Thats saw dust from my garage. Lol i was doing a bunch of wood work over the winter and poor bike got a little covered. Lol
Side note. Carbs came out of the ultrasonic tank looking pretty good. Well, definitely better than before.
Offline RustyOlive
  • rustyolive.com
« Reply #488 on: February 24, 2017, 03:50:49 PM »
Spiffy clean.
Offline RustyOlive
  • rustyolive.com
« Reply #489 on: February 26, 2017, 04:18:31 PM »
Reassembling the carbs today.
Somehow I over looked the difference in spring lenght on the fuel mixture screws. Has anyone seen this before? Anyone know which carb it goes in? Or is this a mistake? I have an old set of cb650 carbs.. perhaps I can swap the springs out if they should all be the same lenght.
Offline akabek
« Reply #490 on: February 26, 2017, 05:35:43 PM »
I took a quick peak online and any rebuild kit I found for a 1978 CB750 carb uses the same spring and screw for each carb.
« Last Edit: February 26, 2017, 05:53:46 PM by akabek »
Offline RustyOlive
  • rustyolive.com
« Reply #491 on: February 26, 2017, 06:02:34 PM »
Already been looking at parts list. Considering the spring is listed as one part number and rebuild kits that include that spring are part numbered per typical. I would say the short spring is someone's previous attempt to improvise. But also curious if anyone else had two cents on this.
Offline RustyOlive
  • rustyolive.com
« Reply #492 on: February 27, 2017, 03:09:20 PM »
Pulled out the springs in an old set of cb650 carbs. All four of the springs are the same lenght as the long ones in this set. So I stole a spring and replaced the short one. Carbs are done and ready to go in. Hopefully tomorrow or Wednesday. Crossing fingers. Lol
Offline RustyOlive
  • rustyolive.com
« Reply #493 on: February 28, 2017, 05:51:41 PM »
Well there you have it! She runs!
Tomorrow i will fix the exhaust leak. Build the baffle and slip on the reverse cone. Button up the air plenum box and air filter. Sync and tune in this old girl!
GREAT! So now the video won't upload to this bs website.. man! This site needs some serious updating! Lol
Offline GV1390
  • Express Gratitude.
« Reply #494 on: February 28, 2017, 05:53:13 PM »
Old Canadians and technology must not mix!
Dude, seriously congrats on getting it going though, stoked for you! Now no excuses to ride this season.  ;D
93' GSX-R1100, 78' CB550, 71' CL350, 71’ CB500 & 02' ZRX1200R.
Offline RustyOlive
  • rustyolive.com
« Reply #495 on: February 28, 2017, 05:59:24 PM »
Blah blah blah. Least we can elect common sense and respect for one another... hahahaha.
Thanks. Looking forward to summer already! Lol
Offline RustyOlive
  • rustyolive.com
« Reply #496 on: February 28, 2017, 06:00:14 PM »
Offline GV1390
« Reply #497 on: February 28, 2017, 06:00:37 PM »
Respect? You guys kept calling me yankee last time I visited!!! lol.
Heck yeah dude! Now get the XL going. Love that thing.
« Last Edit: February 28, 2017, 06:08:35 PM by GV1390 »
Offline RustyOlive
  • rustyolive.com
« Reply #498 on: February 28, 2017, 06:04:18 PM »
Well.. your prez doesn't have much of that "r" word.
Yeah. Once the cafe is solid. The XL will be on the table. And then the fatty 550. Lol
Offline RustyOlive
  • rustyolive.com
« Reply #499 on: March 01, 2017, 12:42:15 PM »
So interesting fact... bike runs even better than last video... after i saw that one of the wires to the right side coils wasn't pulled in .. hahahahaa imagine that eh?
Got an oil leak from the oil pan it looks like. And still need to fix an exhaust leak at the header. I'll try to do that when weld up the inner baffle and modify the header to fit the reverse cone this week.
Video from this morning.
