Author Topic: Valve Adjustment  (Read 2552 times)
Offline BoCoJohn
Valve Adjustment
« on: January 06, 2011, 06:46:35 PM »
Has anyone else noticed that the Valve adjustment table in the Maintenance Operation section of the 1973 CB500 manual is incorrect - I think?
Under the heading: 1. TAPPET ADJUSTMENT, paragraph 6 is a table that states when the No. 1 cylinder is at TDC of the compression stroke you adjust:
inlet and exhaust of No. 1
exhaust No. 2
and inlet No. 3
when I think actually you adjust inlet and exhaust No. 1 and  inlet No. 2 (instead of exhaust) and exhaust No. 3 (instead of inlet).
Does anyone know which is correct?
1973 CB500
1973 CB750
1974 MR50
1975 MR50
1983 IT490
1984 XR500
1969 CT-175
Online Deltarider
Re: Valve Adjustment
« Reply #1 on: January 07, 2011, 02:22:00 AM »
The table is right.
CB500K2-ED Excel black
Offline JBMorse
    • Travel Blog
« Reply #2 on: January 07, 2011, 06:52:46 AM »
I can't remember exactly but I think there was a typo in either the table or the text that showed one incorrect valve.  The easy way is to remember is to turn the crank as instructed, then adjust the valves that wiggle.  You should be able to move all the valves you're adjusting ever so slightly.  Then turn the crank 360 degrees and adjust the valves that are now wiggling.
And of course make sure the lock nuts are all tight after.  I once left one loose and it came off and was rattling around in the valve cover for a while :o
1971 CB500K
« Reply #3 on: January 07, 2011, 07:03:21 AM »
table is correct: If 1 then 2ex, 3in; If 4 then 3ex, 2in.
Checking for the clicking valves works with the infrequent but possible exception that if a valve has tightened rather than loosend, it won't click. A tight valve would indicate other problems, the valve, or seat, has settled, and the valve is possibly burned. The more likely cause is a poor prior adjustment, the valve lash tightened up when the lock nut was turned and the mechanic didn't catch it.
Offline JBMorse
    • Travel Blog
« Reply #4 on: January 07, 2011, 07:57:59 AM »
Hmmmm really?  Now I'm wondering if I've been adjusting that one tappet wrong.  Next time I do and adjustment I'll pay very close attention to this.
1971 CB500K
« Reply #5 on: January 07, 2011, 09:49:29 PM »
i allways do each cylinder on its own compression stroke anyway,follow the firing order as you go,that way you WILL have the cam at the base circle,even on diesel trucks ill do it the "long way".
Offline Whaleman
« Reply #6 on: January 08, 2011, 06:22:52 AM »
I have always just turned crank until #1 intake goes down then up and continue to T1-4 then do #1. Then turn until #2 intake goes down the up and continue to T2-3. I just do 1 cylinder at a time. Has always worked and no charts to remember. Dan
« Last Edit: January 08, 2011, 10:07:30 AM by Whaleman »
Online Deltarider
« Reply #7 on: January 08, 2011, 07:20:25 AM »
I have always just turned crank until #1 intake goes down then up and continue to T1-4 then do #1. Then turn until #2 intake goes down the up and continue to T2-4. I just do 1 cylinder at a time. Has always worked and no charts to remember.
That's indeed the best way.
« Last Edit: January 12, 2011, 04:19:27 AM by Deltarider »
Offline tlbranth
« Reply #8 on: January 08, 2011, 09:15:03 AM »
Put the book away. When #1 intake is all the way open, adjust #4 intake.
                           when #1 exhaust is all the way open, adjust #4 exhaust
etc.
1 & 4 are opposites.  2 & 3 are opposites. When a valve is fully open on one, its counterpart is fully closed on the other and can be adjusted.
This'll work for any inline 4 engine that I ever saw.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline Mark M
  • This is what the 10 year old me wanted for Xmas
« Reply #9 on: January 08, 2011, 09:24:29 AM »
Cross plane cranks are a little different though ;D
In the UK anything over 40 years old only needs insurance and Fuel.
« Reply #10 on: January 08, 2011, 01:22:18 PM »
etc.
the cam still wont be fully on the base circle as its just finished closing,on the compression/firing cycle you can do both valves and they WILL both be clear from the ramps for sure.
