Author Topic: 1972 Kawasaki G5  (Read 2911 times)
Offline catzor
1972 Kawasaki G5
« on: January 07, 2011, 11:43:43 AM »
I decided to help out a family friend and try to use my skillz(all three of them) to try to get his old kawasaki 100 running for the grandkids. I've got the carb sorted, and I'm getting fuel. Compression seems good and I'm getting a good air charge. So all that's left is that pesky spark. I've got a weak one, but I don't understand the electrical system on this old bike well enough to know my next move. Is it like the old 70s twins that simply wouldn't run without a good battery? The battery is in place, but undoubtedly long since dead. Do I need to remove it in order for the bike to run right off the magneto? Would it be easier to start with a good battery in place? Any help would be greatly appreciated! Thanks guys.
1991 CB250 Nighthawk
1986 VT500C
1989 EX500
1973 CB175 Super Sport
Offline kirkn
Re: 1972 Kawasaki G5
« Reply #1 on: January 07, 2011, 12:36:17 PM »
Hi, catzor,
I have a 28-meg .pdf file of the Kawasaki Shop Manual for the rotary valve singles, that includes that model.  I owned a G5 7 or 8 years ago.  It had a spark system that, I swear, would spark through grease!  PM or email me, and I'll send you the manual, if you want.   kirkcheri  (at)  msn (dot)  com
Meanwhile, I'll root around in it and see what troubleshooting help I can find.  I just don't remember off the top of my head re: the battery, but I surely seem to recall no battery required at all for spark.
*EDIT*  a quick read confirms - no battery required for spark.  So, straightforward troubleshooting applies - you need a good spark plug (one that has been confirmed to spark well in some other vehicle); good connections in the system, including grounds; it has points and a condenser, so maybe check point gaps and give 'em a quick touch with a points file; check the resistance readings on the coil windings, although I don't know what values they should be, right off; and check the spark plug cap where it attaches to the the plug wire - make sure it's a good connection - maybe even remove the cap and "prune" the last 1/4" off the old lead to ensure a good connection.
Good luck!
K.
« Last Edit: January 07, 2011, 12:56:33 PM by kirkn »
