Author Topic: Easiest Way To Access the Wire Harness  (Read 637 times)
Offline sh1bby69
« on: January 07, 2011, 11:17:51 PM »
I need to go through the entire harness to make sure all the wires are intact and to figure out why the signals aren't working. Also I have to go through it to figure out why the rear brake light doesn't trigger when i hit the brake.
2008 Piaggio MP3 500
1973 Honda CB 500 with a Velorex Sidecar (Restoring)
My Progess
Re: Easiest Way To Access the Wire Harness
« Reply #1 on: January 07, 2011, 11:58:44 PM »
test your switches and fuses before you unwrap the loom,does it look melted anywhere?
« Reply #2 on: January 08, 2011, 12:46:39 AM »
Most of the connections are inside the headlight bucket. Download the wiring diagram, (find one in color) and take your time. I printed a diagram and glued it to cardboard so I could hang it in easy view.
Offline Mark M
  • This is what the 10 year old me wanted for Xmas
« Reply #3 on: January 08, 2011, 09:12:38 AM »
Patience works wonders,
Work your way through every connector on the bike, pull it appart, clean both ends, reconnect, do the next one.
It's well worth a day doing this on such old bikes, even connectors that look good have often built up a
insulating coating internally.
In the UK anything over 40 years old only needs insurance and Fuel.
